calculating compression - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2012, 11:30 AM
Hi I need help calculating my compression to see if I can run on pump gas. If you could help me figure this out id appreciate it her is all the info
on my motor thanks Joseph
engine is supposed to be about 410 smc
Bore: 30 over Stroke: It is a 6 inch rod
this is the piston specification that i got with the motor they are Racetec pistons. i do have a picture of what the piston looks like if you would like me to email you a pic or somthing.
The actual piston compression is 11 to 1
Engine Information Head type: 40/60 SHIFT Bore diameter: 4.165 in Stroke: 3.750 in Rod length: 6.00 in Displacement/cubic: 408.7 Comp distance 1.125 in Ring Info Ring Number: AT8165 (not sure if this helps) Rail info Rail number: 3.845-168 Wrist Pin Info Pin Type: chamfered Pin number: 927-2700-51-15c Diameter: 0.927 in Length: 2.700 in Piston Information Piston type: dome diameter Diameter 4.1620 in Weight: 456 grams Deck to crown thickness: 0.220 Forging type: A4123F N/C Dome Volume: -.400 cc Gauge point: 0.200 in Ring groove width Top Ring: 0.0640 in 2nd ring: 0.0640 in Oil ring: 02180 in Land width Intake- depth: 0.280 in ,angle: 23.0 degrees Exhaust- depth: 0.280 in ,angle: 23.0 degrees
im not sure wat piston deck height is but i do not piston was flush with the deck if that helps.
gasket thickness im using mls 1144 fel pro -gasket bore: 4.200" -comp volume: 8.9cc -thickness: .040"
i have AFR 210 heads with 75 cc chambers
the drive train is a complete roller The camshaft is a solid roller specs are: lift: .630 Lobe Centers: 106 intake opens at 21 degrees close at 52 degree exhaust opens at 54 degree close at 22 degree
intake is 253 @ .050 0.0200 is 284
exhaust is 256 @.050 0.0200 is 288
Old 03-21-2012, 11:40 AM
SSedan64's Avatar
2 Calculators here >> http://www.kb-silvolite.com/calc.php should help you.
Old 03-21-2012, 02:14 PM
I did it and im getting like 7.86 I don't think that is right but im not sure what I am doin
wrong. Maybe you can get the right ans
Old 03-21-2012, 03:25 PM
SSedan64's Avatar
I got:
11.459 Static Cr.
8.980 Dynamic Cr. w/67* Intake Close ABDC & 6" Rod.
Using these Specs:
4.165" Bore X 3.75" Stroke.
.040" X 4.200" Gasket.
-4.00cc Dome Piston.
0" Deck Height, 75cc Chamber.
Old 03-21-2012, 03:46 PM
compression
I got:
11.459 Static Cr.
Using these Specs:
Hey thanks that sounds better. Which one do I look at so that I know if I can run pump gas.
Old 03-22-2012, 12:39 AM
anyone else think they can help
wondering if anyone else could help me calculate my compression that you go by to decide if you run on pump gas or not?
thanks appreciate it
Old 03-22-2012, 10:10 AM
Originally Posted by F-BIRD'88
You'd be much better served to build this engine with a real measured cr of 10.5:1 or less for premium pump gas and street use.
11:1 is a little too aggressive. Especially if you have to ask about this stuff.
Well I understand that but this is what I got im just trying to figure out the actual compression you go by to determine what octane I can run on
Old 03-22-2012, 10:41 AM
bigdog7373's Avatar
Of course it's fast
Static......
Old 03-22-2012, 10:43 AM
Originally Posted by bigdog7373
Static......
Yea I guess is that what you go by to determine what octane to go by.
Old 03-22-2012, 10:46 AM
bigdog7373's Avatar
Of course it's fast
You are correct.
Old 03-22-2012, 11:49 AM
You are correct.
Do you think you could tell me what you come up with?
Calculating HP for my engine glessen Engine 1 08-29-2006 12:24 PM
HP calculating PHATHOM Engine 0 06-06-2006 12:19 PM
calculating piston dish cc? firechicken383 Engine 2 06-13-2005 09:16 PM
Calculating speed Novaman78 Transmission - Rearend 5 03-06-2004 09:08 AM
calculating cruise RPM? laitch Engine 4 01-28-2004 09:18 AM
