Calgary area body shop.....need a little help with the Chevelle - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2011, 09:43 PM
wickster's Avatar
I replaced my door hinges and had the front fenders and hood off this winter.....now I cannot get anything lined up in the front end.
I am out of my league and need a recommendation of where I can take the car to get the panels at least reasonably straight and doors lined up?
Doesn't need to be show quality but would like it to a least be close.
Any advice would be appreciated.
Old 05-10-2011, 04:56 AM
poncho62's Avatar
Wiki Edits: 5
I guess when you took it apart, you didnt take notice of where all the shims went........should have.
I am sure one of the experts here can give you a heads up
Ontario Rodders
Old 05-10-2011, 07:19 AM
wickster's Avatar
Well.....I did have the shims separated and neatly stacked on the work bench.
My beautiful daughter though she would help by rearranging the stacks so the same sizes were all together.
Old 05-10-2011, 08:39 AM
Little OCD, huh? My little grandson has lots of fun with this.
Old 05-10-2011, 03:18 PM
Chris Ryan
Wickster, If you can turn a wrench you should be able to handle this.
I assume its all painted so you must be careful, tape all edges to prevent oops.
Obviously the qtr panels didnt move so I would start there and move forward. I find it easier to remove door latches when aligning doors. Once u have both door/ qtr gaps set, move onto the fenders and finally the hood. Since it is painted and finished you may have to play a little game of give and take with the gaps. There's no big secret, it just takes some time. You may loosen panels and take shims in and out several times. You'll get it. Goodluck....chris
New Posi and Gear Installation...Shop Recommendations in Calgary wickster Transmission - Rearend 0 04-24-2006 11:33 AM
Body shop in The Bay Area sscamaro_510 Body - Exterior 4 12-18-2005 11:54 PM
good shop in L.A. area?? ethan Transmission - Rearend 0 01-05-2004 12:07 PM
Looking for a good Paint and Body Shop in the OC Southern Cal Area Mitch Body - Exterior 4 11-03-2002 06:26 PM
San Francisco Area Paint Shop billcar670 Body - Exterior 3 10-24-2002 05:33 PM
