is it the caliper, or the hose collapsed - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2010, 11:29 AM
fast68's Avatar
likes chevy trucks & boobies
im trying to think of a good way to tell if its a collapsed hose, or the caliper piston thats frozen causing stuck front brake on a 98 achieva i got to go work on later
any idea
Old 05-24-2010, 11:45 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
All the delaminated hoses I've run into were bad in such a way that the fluid was blocked going into the caliper, not in a way that would cause the caliper to seize up on the rotor. Even if it did, it would only be momentarily until the fluid "leaked" around/past the delamination.
On a '98, I'd just about bet it's the caliper.
Old 05-24-2010, 11:46 AM
powerrodsmike's Avatar
Wiki Edits: 161
Loosen the bleeder...Collapsed hose will free up the caliper, and a stuck piston won't care if the bleeder is open or not.
later, mikey
BE different....ACT normal.
Old 05-24-2010, 11:51 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If this thing is rusty underneath, check the bracket that holds the hose from fouling on the suspension. The center of the bracket can rust up bad enough to cause the hose to be pinched and will make the brake drag.
Might take a close look at the hard line to be sure it's not been pinched shut as well.
Old 05-24-2010, 03:05 PM
fast68's Avatar
ive had a 79 chevy van that a collapsed hose and it caused a stuck brake.,
so it is extremely possible.
also same on this 91 chevy truck we have in the shop right now that we are replacing the basically dead 342k miles numbers matching original 305 in.
a bad hose causing a stuck brake has actually been more common than i expected over the years..
and applying brakes is alot of pressure through the hose.
letting off the pedal is lower pressure back up the hose. cant do it when hose is collapsed., so stuck brake. you gotta think backwards on some stuff'
bleeder screw idea is good that should do it
i shoulda thought of that one haha duh
the rusted hose bracket thing is really good too!
im sure its a rusty one its got a ton of miles on it he says and he drives it alot every day.... im sure its beat bad
going to go fix it really soon here as soon as the guy is home from work any minute now
thanks!
update:
well replaced the caliper for hi last night, could not see any rust in the bracket that holds the hose back and the hard lines all perfect condition, i first applied the brakes and then check the rotor and it wasnt frozen in place and there was no pressure in the caliper when i opened the bleeder so i was kinda stumped and decided that i guess the hose is not the culprit on this one. and went ahead and replced the caliper
so far so good i havent heard anything from him since and he was super happy he even gave me 80 bucks for doing it and it only took like 20 minutes to do. he said he just moved down here from alaska a year ago, and he told me all about what its like up there.,. apparently now they now pay you 6000 or 6500 a year to live there thanks to that sara palin pulling some strings?? hmmm... he didnt like the heat at all down here, it was 95 all day and he wasnt happy lol. i like it... its great, screw winter time. i hate that stuff. this heat kicks *** he said that oil work up there is 25 an hour starting out..... wow...
the car is actually pretyt nice 130k miles 98 achieva runs drives excellent and clean body and we own one identical to it same color and all, and he knew about it already.
i was like yeah we own that one and its for sale.
then he says his is for sale too, and he only is asking 700 for it.
i told my stepdad who owns the other one, and he is interested and probably gonna snag it up and clean it up some, and resell it for profit,
i would do the exact same if i had the cash on me.
i got this repair job from craigslist site just poking around on it yesterday.
i told him to spread the word for me that i'll repair anything i can for anyone.
not just at the private shop we own.
and it was even only two blocks away from here lol. weird stuff.,,,,
welp im out, gotta figure out if i want to work at the painting job today or at the restaurant, or at the shop today, too many job choices to choose among hmmmmm...... uhmmmmm....
thanks again!
Caliper Doesn't Release quickly? Psquare75 Suspension - Brakes - Steering 14 12-12-2009 03:39 PM
DOT approved or not? staleg Suspension - Brakes - Steering 14 06-19-2007 07:58 AM
Braided fuel hoses all leak gas vapor odor? Steve S Engine 2 04-26-2007 09:52 AM
Banjo fitting illegal?? gavinpierce Hotrodding Basics 10 04-22-2006 10:08 AM
1974-78 Mustang II caliper hose adapter? hrussel Suspension - Brakes - Steering 1 02-28-2005 04:10 AM
