Caliper piston area - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2009, 05:29 PM
need strog32 chevy front doors
Last journal entry: LittleFloor
Caliper piston area
Any one know how i can find out how big my rear caliper pistons are on the rear end i want to put under my 32
The rear is disc from a 1998 sonoma
Old 05-27-2009, 10:33 AM
Um, use a ruler? Not to be a **********, but the size of the caliper pistons is simply the piston diameter.
Old 05-29-2009, 08:49 PM
Sorry i meant to ask how do i determine the piston area size needed for my aplication
Old 05-29-2009, 09:07 PM
powerrodsmike's Avatar
Wiki Edits: 161
You do like most of us, and could make a reasonable guess by looking at a car with similar weight, weight distribution and equipped with brakes that perform at the same speeds you expect to be going, on the same size tires you expect to use,...and get a set of those, or you could work backwards , like the brake engineers do....
Start here.http://www.stoptech.com/tech_info/te...e_papers.shtml
then this:
http://www.stoptech.com/tech_info/Th...%20Systems.pdf
Then read this:
http://www.stoptech.com/tech_info/fo...g_dynamics.pdf
Here is a link to a very good article on Pirate4X4, it has LOTs of good stuff, and is, by far the best online brake design article I've seen yet.
http://www.pirate4x4.com/tech/billavista/Brakes/
Thank Triaged for that one.
Somewhere Triaged had shown me a link to a good online calculator, in an excell spreadsheet format, to do the math once you plug in all of your values, but that was 2 computers ago and I can't find it now...
Ford explorer disc brakes work good, the GM calipers kits for rears that most sell are a PITA.
You don't need alot of rear brake on a 32.
I just noticed on your first post where you said you had disc brakes from a 98 Sonoma, check to see if these are low drag calipers, they cause alot of problems if you don't know about them.
Later, mikey
BE different....ACT normal.
Old 05-30-2009, 11:49 AM
I posted one here before that was made for dual master cylinders with a balance bar (like a Wilwood pedal setup).
http://www.hotrodders.com/forum/atta...achmentid=9848
this is where I got it from
http://sceep.boogerwelds.com/sob/jeep_brakes.xls
This one can be found about 2/3 of the way down in the link Mike posted and it is done for a conventional tandem master cylinder. Read the link for the explanation of how it works.
http://www.pirate4x4.com/tech/billav...BillaVista.xls
The easy answer is to make sure the piston area and rotor size is the same or a bit smaller on the rear than the front and to put in an adjustable prop. valve.
Old 05-30-2009, 12:11 PM
Wiki Edits: 161
Thanks Triaged, I knew that billavista page had a calculator on it somewhere, you sent it to me before but last night I couldn't find it anywhere....
I still owe you a copy of that Ferodo brake engineering handbook from the old days....
( scanned a few pages in and then my scanner crapped out...but I haven't forgotten)
Later, mikey
Old 06-05-2009, 07:20 PM
How much smaller is acceptable for the rear caliper ..
Alot of calculations am going to guessamate the cg and weight of the car and ... make some calculations.
i figure 700 psi will be made from the ratio I plan to use and the mastercylinder 1 inch bore.
now i just need to find out if thats aprropriate for stoping the car and if the calipers can handle that
Old 06-08-2009, 10:15 AM
I think I'll stick "a bit smaller". Either that or go through all the calculations. An adjustable prop. valve is inexpensive and able to make up for having too big of rear brakes but can't do anything about too small.
Old 06-08-2009, 08:18 PM
Here my calcs , did i do it right.
(75lbsX6)/ .7854 = 573 max psi out MC (75 lb leg force, 6 pedal ratio, 1inch diam MC)
I know this is the psi in the rear line and front line but does only one front caliper see 573 psi or is it split amongst the two front calipers so that each sees half of 573
Proceeding with calculations
I over assume that my car weighs 2500lb with a center of gravity (found by balancing on jack and 4x4) acting 50" from the front tire. 112" wheel base
Statics problem
Sum of the Forces=0 = 2500 - ForceA - ForceB = 0
Sum Moments about point A (the front axle)= (2500)x 50 - ForceB x (112)
ForceB=1116
ForceA=1384
TorqBrequired(for both rear brakes)= 1116X1X15 =16740
15inch radius tire , friction 1, 1116 vert force
ClampForce= 573x ( 5.939x2x2) = 13612.18
max psi x (effective caliper area) . effective caliper area is for a 2.75" diam pist and this effective area = 5.939x 2 x 2 .. theres two calipers and there floating ones thus 2 x 2
Torq brake developed= 13612.18x .3x6= 24502
Clampforcexdiskfrictionxpad arc
is it right
I did calcs for a 2.75" diam piston which is the same size thats i do have for the front . calcs for a 2 and 1/8 pistons put me shy of the needed about
but i did over estimate the total car weight.
So if i did this all right I would purcase metric gm calipers and buy or fabricat this mounts and weld or bolt them to the rear while using the original 3/4" this rotors that are 12 inch in Diam. why because they are the hat style ebrake type.
Old 06-08-2009, 10:12 PM
See answers in red.
(75lbsX6)/ .7854 = 573 max psi out MC (75 lb leg force, 6 pedal ratio, 1inch diam MC) Yes
I know this is the psi in the rear line and front line but does only one front caliper see 573 psi or is it split amongst the two front calipers so that each sees half of 573 Both front wheels will get 573psi because of Pascal's law that "a change in the pressure of an enclosed incompressible fluid is conveyed undiminished to every part of the fluid and to the surfaces of its container."
I over assume that my car weighs 2500lb with a center of gravity (found by balancing on jack and 4x4) acting 50" from the front tire. 112" wheel base Ah...the fun way to find the CG
Statics problem
ForceB=1116
ForceA=1384That is the static load on the tires. You will need to find the weight transfer from the back wheels to the front during braking. In order to do that you need to know the vertical location of the CG. Many people guess'timate it as the height of the top bell housing bolt from the ground.
15inch radius tire , friction 1, 1116 vert force Friction=1 is for warmed up sticky tires. Friction=0.8 would be better for normal street tires on dry pavement
max psi x (effective caliper area) . effective caliper area is for a 2.75" diam pist and this effective area = 5.939x 2 x 2 .. theres two calipers and there floating ones thus 2 x 2 Clamp force doesn't need the 2nd "x2". However because there are 2 pads I would put it below. Doesn't change your answer
is it right Pad arc should be from the spindle axis to the center of the pad, not half of the rotor diameter (I'm just guessing you are using 12" rotors up front). See what BillaVista has to say about DOT edge codes to find the coefficient of friction of your pads. 0.3 looks a bit low to me if you are using performance pads. My Hawk HPS pads are FF so 0.35-0.45 hot or cold if I recall correctly. http://www.pirate4x4.com/tech/billavista/Brakes/#Pads
but i did over estimate the total car weight. When you include the weight transfer chances are those metric calipers would be a bit big and need a prop. valve (exactly what you want).
So you have full size GM brakes in the front with 12" rotors?
Old 06-08-2009, 10:24 PM
Thanks... I plan on welding caliper brakets on the rear axle or making bolt on one to fit big gm metric calipers. Is it safe to use the original type rotors they are 3/4 inch thick oppesed to the inch thick one in the front. Using there type rotors to keep the stock reares e brak system.
speedway has brackets but they look thin
Old 06-08-2009, 10:31 PM
Didn't GM make "metric" calipers that were for a 0.84"ish rotor? I don't know how much piston stick-out is ok. You want to be sure the piston won't pop out when the rotors are at discard thickness and the pads worn down to steel. You might also want to read up on the low-drag calipers. There have been a few threads recently about not being able to get the older non-low drag calipers. You might need to run a residual pressure valve and/or a manual brake S10 master cylinder if you can only find low-drag calipers.
Old 06-08-2009, 10:37 PM
Wiki Edits: 161
Great stuff
I wished I could figure out how to do the math part..Oh well.
IIRC, some of the circle track supply places like coleman racing and speedway motors (in the race catalog) sell pad spacers to make a metric caliper run on the thinner rotor....
Later, mikey
Old 06-11-2009, 12:15 AM
How do you guys feel about piston spacers or brack pad shims. Im looking a running a caliper meant for 1 " thich rotor on a 3/4" thick rotor
Old 06-11-2009, 08:39 AM
Wiki Edits: 161
A friend of mine has 1/8" spacers tack welded to the back of the pads on the front of his 46 Ford PU, his MII kit from Fatman came like that, he's been running them for years with no problems.
Later, mikey
stroke to rod ratio jacobm99 Engine 17 09-16-2010 10:06 AM
big block chevy piston to wall clearance question Ratoflic Engine 24 06-22-2006 04:16 PM
Piston Oilers Fastnuf Engine 13 04-08-2005 09:25 AM
Ford Explorer Brake Caliper Problems Jag Daddy Suspension - Brakes - Steering 4 05-08-2004 12:48 AM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
