I would think you would need to have the pad machined completly flat. A machine shop should be able to touch it. Most likely cheaper to buy an exchange caliper unless it is a real fancy one.
I would'nt trust JB at a point like that. |
Do you realize the amount of pressure the brake fluid is under during stopping? The pressure will imediately blow out the rubber and then you will be left with no front brakes... |
Also trying to polish the imperfection out will cause the mating surfaces not to be square resulting in a pressure leak (and subsequent drawing of air). It has to be surfaced on a mill or discarded. |
