Calling 347 experts
My winter project this year is going to be a 347 that I already purchased. I need some help with some information
1). I know the 347 will be held back with stock heads, and I have a seperate pair of ported stockers. I've read that there's not much benefit from the ported ones, but I'm not going to be building a horsepower monster, it's mainly just for a fun muscle cruiser I'd like to eventually work towards.
2) Will 24 pound injectors be sufficient for the 347 (assuming I use the ported heads)? How about the stock fuel pump?
3) If I do decide to get heads, it will be a gt40 variant to save money. Which one would best suit my application, and will I need bigger injectors than the 24s, and stock fuel pump?
4) The guy I bought the stroker kit and misc. parts from says there's a "flow tube" I can buy to fit in the MAF that he gave me that is calibrated for 36 lbs (or whatever is around that size).
5) I currently have an E303 with new pushrods and lifters. I also have the lunati #51014 cam. The specs for it are
•Advertised Duration (Int/Exh): 284/292
•Duration @ .050 (Int/Exh): 218/226
•Gross Valve Lift (Int/Exh): .500/.510
•LSA/ICL: 112/108
•Valve Lash (Int/Exh): Hyd/Hyd
The appear similar, a little different. I've been told I'll get more power out of the lunati cam, but I love the sound of the E303 and for my ultimate appearance of the car, would rather have the E303. Anyway, since the specs are so simliar, would I run into any problems using the same lifters and pushrods if I were to use the lunati?
Thanks for the help, I know a lot of my answers depend on each other.
