Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Calling all SBC gurus
Old 12-12-2012, 04:46 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Xgasser View Post
Thanks Bill for your input. I realize you don't needa lot of oil but I'm not getting any... except for three that barely dribbles out. It's not even enough to lube the rollers (Crane roller rockers) on the valve tips. I may end up pulling the lifters out and checking them. I was even thinking about trying a new set of lifters but hate to do that to the cam/lifter match. Getting desperate here...
Have yiou tried adding/subtracting lifter preload to see if there a 'sweet spot' where they oil better? If you could adjust on them w/the engine running, that would show you pretty quickly if that was gonna help.
If the geometry is off (like Richiehd said), that might cause it.
Obviously a missing gallery plug could do it but I wouldn't have expected to see good pressure.
I'd be a little worried if you heard a noise then the pressure dropped. Any idea where in the engine the noise came from?
