calling camaro experts - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2009, 03:10 PM
hello
I have two camaro subframe . one is a 71 the other is 74 .trying to put lower control arms on the 71 sub from the the newer one . There seems to be a differece in the dia . of the bolts . Why is this ? and what should i do to make it work ?
Thanks larry
Old 10-08-2009, 07:13 PM
change ups
the holes are different probably because GM just changes things... talk to a front end shop... always go to an expert....even on the dumbest things...you know what they say about asking dumb questions...... lol..
Old 10-14-2009, 08:17 AM
68RATVT's Avatar
Last journal entry: 46 Dodge frame
From what I barely know, 68-72 are the only years that cross over with your 71. 489 is right, if you have to use the 74 arms, better check with a front end shop, the geometry may be different also..
Old 10-15-2009, 12:17 PM
streetrodderbn's Avatar
Certifiable Streetrodder
67-9 is a different front suspension, it usually interchanges with nova, but not later 1970-81 camaro
Old 10-17-2009, 06:05 AM
I think they did change the bolt size. Just use the bolt from the 74 drill out the lower control arm mount hole to the proper size.Dimensionaly the arms are the same.
Old 10-26-2009, 05:31 PM
subframe update
:: hello
There is a difference of close to 1" between a 71 upper contol arm mount and a 74 /75 on . Plus the arm pivot bolts are not the same diameter. I need a later model subframe to match the control arms . ughh
Larry
Camaro projects for sale... Zartan General Rodding Tech 30 12-12-2008 11:01 AM
Yep! I'm new 2.... Pro-Touring a '67 Camaro L8model Introduce Yourself 6 12-09-2004 12:30 PM
'36 P/U, 69 Camaro subrame engine help!!! Apathy93Z Engine 1 12-08-2004 06:54 AM
78 camaro to t top 87 monte carlo help isleofwight Engine 3 06-28-2004 09:29 PM
94 Camaro lt1 Vs. 95 Camaro lt1 NEEDHELP Engine 3 11-05-2002 11:45 AM
