Calling the DOC..66 Impala headlight switch issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2006, 11:30 PM
black66's Avatar
www.airriderz.com
I rewired my car last summer and I have been finishing up all the loose ends.
Everything is working except my tailights.
Here is how my headlight switch is wired minus the green wire ( backup lights)
That is not my actual light switch but it shows the correct wiring position. If I turn on my headlights my tailight do not come on. If I run a hot wire directly to my tailights (brown wire left of blue wire) the tailights will come one.
Now I do not have the green wire ( backup lights) hooked up on my headlight switch. But after reading my wiring schematic and looking at the headlight switch the tailights seem to get their power from the backup lights ( green wire). The taillight terminal and backup terminal on the headlight switch are joined toghether by a brass piece. So I jumped at hot wire to the back up terminal on the headlight switch. The tailights would come on but not shut off? What am I missing.....???
Turn signals, headlights and brake lights all work. And tailights will work if I supply a hot wire directly to the taillight wire. But I can not get the tailights to work by just pulling the headlight switch on???
Dave
Old 06-01-2006, 01:07 AM
Snick
It look's like you have a really good wiring diagram. I've alway's just taken it just one wire at time (having alway's done it by scratch) how ever your parking light's are on the same circuit as Your tail light's. I hope this help's If knot post again I will try to help more.
Old 06-01-2006, 03:16 AM
docvette's Avatar
Wiki Edits: 12
Doc here ,
Your problem is very simple ...
you mis-wired it.
FIRST: Backup lamps NEVER go through a headlight switch ..AND they should be green with a BLK tracer not green..Their correct configuration will be , one wire from the fuse marked "Backup lamps" to the backup lamp switch..then directly to the backup lights..should all be Green/Blk wires. NOT the same circuit..
The Tail lights are Brown on the vehicle side, at all the lamps up to the switch..It receives it's power from the green wire FROM the headlight switch which goes to the "Instr Lamp Fuse" on the fuse panel..This wire supports power to the tails and the instrument lamps (used to be the way we could tell the tail fuse was blown when driving at night..the instrument lamps were out ) This circuit has nothing to do with the backup lamps..
The backup lamp fuse is on the switched side of the fuse buss, the tail lamp / instrument fuse is on the "hot at all times" side of the buss.
If you follow your own drawings out , at the bottom drawing the brown goes back to the headlight switch..then the green from the head light switch goes out ( and off the drawing and re appears on the top drawing as a green) and goes directly to the fuse panel.
That should correct it.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 06-01-2006, 02:20 PM
black66's Avatar
www.airriderz.com
wire
Doc thanks as usuall. I got the green wire on the schematic mixed up with the back up lights. So the green wire (instrument panel light wire) that "excites" the tailights must be powered from the big blue headlight switch at the fuse panel? Is this correct? On my six six Impala the first pull of the headlights should turn on the taillights correct?
Old 06-01-2006, 02:46 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
The Green From the headlight switch goes straight to the "instrument Lamp" fuse.
The Blue, Or main Headlight power will Go directly to the wire that supports the main fuse buss from the starter and fuse link . Headlights generally have no Fuse in the panel but are protected by the fuse link and a thermal reset inside the switch.
This is why the headlights work without any support from the rest of the system (key on, Acc..Ect..)
When you pull the switch to the FIRST détente, all the PARK lamps should light if it is wired correctly AND the switch is functional.
Doc
Innovations
Old 06-01-2006, 03:18 PM
black66's Avatar
www.airriderz.com
wire
Doc last summer I installed the EZ wiring kit so I did a completel rewire of the car. So the green wire coming into the headlight switch should be the instrument panel light wire, correct??? So on my system where does the tailights get its power from? Because I have tired three different headlight switches and all have the tailight terminal dead no matter what position the headlight switch is in.....
Dave
Old 06-01-2006, 03:38 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
OK, first we must assume that EZ is using stock GM Color wire ('I believe they do..)
NEXT, The "Instrument Lamp " Fuse wire (Green) From the switch, Provides power to the tail lamps and instrument lamps both..It does not provide an output to the instrument lamps..that is another wire.
I am not sure I know what you mean when you say the tails are dead center on three switches, unless you are talking about the brown next to the heavy blue on the plug.
THAT wire is tail light OUTPUT not fused INPUT. That wire gets power from the Green wire "instrument lamps" fuse, and is internally jumpered inside the switch..when the instrument lamps go on, so does the tails..(or park actually)
The reason it tests dead, is BECAUSE there is no power on the GREEN wire on the switch.
To test the theory, just set your DVOM for OHMS scale, R X 1, and put one probe on the brown wire terminal, and the other on the green wire terminal..with the switch off..it should be infinite..now turn it on to the first detent, it should read 000, then the second detent, IT should read 000..this is correct..
just hook power to the green , and it should work normally.
Doc
Innovations
Old 06-01-2006, 03:46 PM
black66's Avatar
www.airriderz.com
Thanks Doc I knew a green wire needed to be hooked up to the headlight switch to make the tailiights work. I just could not figure out from the schematic which one..... Ha ha....
I will get the rest of the wiring loose ends done tonight and report back....
Dave
66 impala front brakes starliner Suspension - Brakes - Steering 6 08-15-2012 07:04 AM
66 impala front brakes starliner Suspension - Brakes - Steering 7 04-29-2005 01:49 AM
Looking for Custom floor mats for '66 Impala brian400ex Interior 1 02-13-2003 11:11 PM
Lowered Springs for a 66 Impala fsiramps Suspension - Brakes - Steering 3 02-13-2003 11:05 PM
66 Impala rear end fsiramps Transmission - Rearend 2 02-12-2003 01:59 PM
