calling ford experts... - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2010, 08:39 AM
Hwyhogg's Avatar
Last wiki edit: Electrolytic rust removal
Last journal entry: power tour
% power loss through drive train...
How much power loss have you guys actually experienced with a 460/C6/9" drive train? Thanks, james
Old 04-04-2010, 01:45 AM
techinspector1's Avatar
Wiki Edits: 326
James, is this a trick question?
Old 04-04-2010, 06:38 AM
Irelands child's Avatar
huhhhhh??
The only power loss I've ever experienced with that engine (4 different vehicles) was when something like a carb, timing chain or distributor/ignition part needed 'help'. After fixing or replacing, all returned to their normal healthy gas guzzling rumble.
Dave W
Irelands child
Old 04-04-2010, 07:32 AM
38mike's Avatar
I'm intreeged
Originally Posted by Hwyhogg
How much power loss have you guys actually experienced with a 460/C6/9" retrain? Thanks, james
Hey, James: what's a retrain? Oh, and did you actually read your post before you hit 'submit?' Next time, please do and you'll maybe get some help...it makes no sense that I can figger out.
GOOD LUCK.
Old 04-04-2010, 08:42 AM
Wiki Edits: 27
460's
The stock timing chains start to stretch after a few thousand miles and the factory retarded the cam as a cheap way to meet smog regs in the 70's . A new double roller chain and gears set straight up is the fastest and cheapest way to get more power. a lot of the distributors have an adjustable vacuum can. pull the hose and use an 1/8 allen to tune re hook up the hose.
Old 04-04-2010, 04:32 PM
Hwyhogg's Avatar
Was that a bow-tie???? My mistake, drivetrain was the word. I've heard power consumption for a C6 is any where from 15--25%. BTW...CHEVY...I don't need any attitude on here...if you don't like the program..simply change the channel!
Old 04-05-2010, 12:35 PM
hp246's Avatar
I think you are referring to parasitic loss through the transmission. I've been told the C-6 loses 6 or 7 horsepower over a toploader.
Old 04-05-2010, 05:26 PM
Hwyhogg's Avatar
Okay thanks, yes parasitic ....couldn't think of it to save my life
Ford vs Chevy question savman1 Engine 31 10-14-2008 07:13 PM
Ford Muscle..what's wrong with them? tm454 Hotrodders' Lounge 41 11-20-2006 12:37 PM
Calling all A/C Experts Stu Cool General Rodding Tech 17 08-24-2006 10:23 PM
Explorer Disc Bbrakes on a 9" Ford Rear End Mustangsaly Suspension - Brakes - Steering 2 10-31-2005 04:18 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
