Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - cam
Thread: cam
Old 12-11-2012, 10:32 AM
cdminter59 cdminter59 is offline
cam
Originally Posted by dirtyfingers View Post
Thank's for info, but after looking at the two cams ,isn't the 268H smaller than the XE262H ?
The 12-238-2, XE262H-10 is the smaller cam. .462/.469 lift and 218/224 duration @ .050. LSA-110 ICL-106* 415 ft. lbs @ 3700 rpm, 348 hp@ 5300 rpm, 17.5 hg @ 800 rpm vacuum The 12-242-2, XE268H-10 .477/.480 lift and 224/230 duration @ .050 LSA-110 ICL-106* 413 ft. lbs @3800 rpm, 342 hp@ 5000 rpm, 15.5 hg. @ 800 rpm vacuum
