cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2013, 08:43 PM
cam
I built a s10 with a 350 engine running around 450 to 500 HP its my every day driver I want to. Put a different can in it that has a awesome big lope in . it what is the best suggestions on what kind of can I should get? And I'm new to this site this is my first post so go easy on me lol
Old 02-20-2013, 09:33 PM
I ment cam not can
Old 02-20-2013, 09:52 PM
vinniekq2's Avatar
If your engine is making 450 - 500 horse power,it will already have an awesome lope.
what parts are in the engine? what manifold,carb,headers,CR?heads?
Old 02-21-2013, 01:41 AM
American Muscle's Avatar
305 Turbo-Fire 240hp
Woooow, really. A 350 making 450-500 will have loads of lope. Unless you spraying a 300 shot. If your 350 isnt loping the slightest, it aint making those hp numbers. Sorry bud
Old 02-21-2013, 08:16 AM
It has a mean loap but I want more loap I haven't had it on a dyno yet the Guy that built the motor said it was pushing 450 to 500
Old 02-21-2013, 09:07 AM
Proud LOSER
He lied....
Old 02-21-2013, 12:14 PM
The guys who give wild HP figures were not alive in the 1970s or they would not make claims like that.
The baddest Corvette of them all was a 1967-1969 L88 427 CI Corvette and it was only rated at 430 HP at 4,000 RPM. . In production trim, the L88 engine had 450-500 HP on racing fuel at 6,000 RPM. Due to insurance and emissions standards, the L88 package was cancelled in 1970
1/4 mile: 124 MPH 11.50 ET
Old 02-21-2013, 12:35 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
There is not one part in any engine that equals the sum total of the parts matched together.
THE TRUTH ONE MORE TIME IS WHAT YOU ARE DESCRIBING IS A POSER CAM!!.
Old 02-21-2013, 12:54 PM
thinwhiteduke's Avatar
Living In The Past
What RPM is idle ATM ?
What cam ATM ?
Duke
350 bored .060 over... XE268 cam, I didn't put a CAM BUTTON IN!!! Dizturbed One Engine 12 08-08-2010 08:50 AM
Do oem 350 sbc roller cam's take the same cam bolts as older ones? eric32 Engine 5 04-20-2009 04:12 PM
Cam bearings 350 chev, cam wont fit in front bearing???? JD's camaro Engine 5 02-07-2008 03:33 PM
Roller Cam Install - Cam Button & Timing Cover Help leejoy Engine 9 12-01-2007 04:28 PM
Cam: Calculate LCA (cam°) from lobe center angles (crank°)? pgtr Engine 2 09-14-2004 07:28 PM
