Cam for a 455 olds, tips, or info wanted - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2009, 03:20 PM
Well I went ahead and put back on the ole Holley 750 Double pumper, Next I am going to be setting the timing to get her crisp.
I think I'm ready to do cam, springs, etc. And more than likely a new stall.
I have found a kit that comes with all the goodies and a Comp Cam.
Im torn between these two kits. (Any input on them is also greatly apreciated)
First one, little midler- http://cgi.ebay.com/ebaymotors/Olds-...Q5fAccessories
And the second one- http://cgi.ebay.com/ebaymotors/Olds-...Q5fAccessories
Is there anything else I should get along with these kits, and which one would be best?
The car is mostly a street car but I like a nice chop in the idle and love to get on it, and strong launches, also it will more than likely end up at the strip a good amount of times.
Thanks fellas and look forward to your knowledge!
Old 09-07-2009, 03:35 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
I have never used the 280H but I have ran the 292 in both a SBC & BBC in a 68 Camaro. I love the sound of the 292 and the power range was good too. I would however check that these kits contain matching components. I have had some experiences with ebay parts and tend to steer away from them now. You could find this same combo in Summit or Jegs and "maybe" have better customer support or satisfaction if something is not right. JMHO
Old 09-07-2009, 03:44 PM
I guess the 292 will be alot more tame on a 455 than a 350.
Heres what is says about it- Street/strip, 3000+ stall, aftermarket manifold, low gears, increased compression. Very rough idle
But I assume they say that with the 350 in mind also??
Old 09-07-2009, 04:01 PM
Olds motors like dual pattern cams due to the crappy exhaust ports. Engle has some nice grinds, like their 40/43 or 43/46. Mondello (yeah, I know...) has some nice dual pattern grinds that are actually Engle cams - the patterns were developed by Joe when he was still actively involved in the company.
Old 09-07-2009, 06:05 PM
Lunati, Bullet, Engle all offer good grinds for the Olds, or contact one of the Olds builders like Bill Travato(BTR Performance, New York), Smitty(M&J Proformance, Ohio) , Dick Miller racing(Missippi), or Rocket Racing(Wis.)
They all have websites with their contact info, and all of them race Olds powered cars.
They all can recommend a good cam(pre-made or custom ground) to match you application. 455's make huge amounts of torque if you dont overcam them
Travato runs NMCA with a 76 Starfire that goes 7.90's with 403 CI of Olds motor.
There are several companies that make bolt on, shaft mounted, adjustable Roller Rockers, including Scorpion and Harland Sharp.
You can also get a basic adjustable set up(Roller Tipped rocker, no roller bearings))from Comp Cams, or buy just the studs and guide plates from Comp and a set of 3/8's 1.6 Roller Rockers from Scorpion
Old 09-07-2009, 07:47 PM
So these arent your basic put in cam and go kits?
Old 09-07-2009, 07:52 PM
It depends on the cam. Since the stock valvetrain in Olds motors is not adjustable, differences in cam lift must be accommodated by the amount of adjustment that can be accommodated by the lifters. SOME aftermarket cams will work with the stock valvetrain no problem. Anything over about 0.500" lift really wants adjustable rockers or pushrods. As noted, the later SBF motors were the same way.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
best performance for olds 455 !!!!!!! 66 442 Engine 3 12-20-2006 01:20 PM
Olds 455 vs. Pontiac 455? bildo95 Engine 3 06-27-2003 04:53 PM
olds 455 build up oldscutlass Engine 1 06-24-2003 08:57 PM
help with 455 olds marine engine 442 chevy power Engine 1 01-03-2003 06:59 PM
