Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam for 460 EFI? EFI - Does it matter?
Old 06-22-2004, 06:49 AM
TurboS10's Avatar
TurboS10 TurboS10 is offline
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Trees is correct. If you change the cam profile, you will need to reprogram or rechip the ECU so it will properly work with the changes. If the cam profile that you select does not have a preprogrammed chip for it available it will take a custom chip.
Chris
