Cam for a 6 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2006, 01:23 PM
strummin67's Avatar
Violating consensual reality
Last journal entry: Taking a short break
Cam for a 6
Can anyone recommend a good street cam for a Daily driven Chevy 194 6 in a Nova wagon? The engine is mostly stock but I will be getting a 2bbl progressive carb and dual exhaust in the future.
Strummin
Old 04-20-2006, 02:05 PM
Wiki Edits: 31
a very light aftermarket or the stock cam.
Old 04-20-2006, 08:48 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
/\for mostly stock daily driver, I'd agree...
Old 04-20-2006, 09:49 PM
strummin67's Avatar
Another guy recommended a cam he had in his 194 years ago. He described it as having 256 advertised duration and .488 lift. The cam was no longer being made but I could use those numbers as a guideline. Always a fan of second opinions I wanted to hear what had to be said here.
Strummin
Old 04-20-2006, 10:43 PM
Wiki Edits: 31
too big for a stock engine.
Old 04-21-2006, 07:10 AM
tnsmith10's Avatar
when will it rain???
Strummin
thats almost the same as what i got from crane... but i have a 250.the lift my cam has is 467/498 lift., and 248/260 duration..
advertised duration @ .050 is 192/204.
it might be a bit too much for a 194... its bordeline for a 250. make sure whatever cam u get u degree it in... when i got mine, after degreeing it in, i had to buy an offset key to get the power where i wanted it...
Old 04-21-2006, 08:39 AM
strummin67's Avatar
I see you went with a split as opposed to a single profile cam. Will leaving the exhaust valve open longer help scavenge the gas out better?
Strummin
Pontiac cam? Wmarden Engine 12 08-22-2010 08:09 AM
Is it possible to degree an unknown cam? Scrumgees Engine 4 03-18-2006 11:50 AM
87 octane engine cam swap? 71C10 Engine 6 01-20-2006 10:50 PM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 01:11 PM
More issues....lets talk cam failure TurboS10 Engine 23 09-28-2004 11:51 AM
