cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2005, 06:36 PM
i need cam help
i would like to put a cam in my mustang it is an aod car it is stock with all bolt ons. stock gear but want to put a gear and stall con after cam it is an efi car. what cam should i use and what needs to be up graded after cam is installied thanks for any help
Old 07-18-2005, 07:07 PM
edge's Avatar
Time is short, are you ready?
Originally Posted by 90lx
i would like to know if i put a cam in my 90 coupe aod car will it go faster?
Depends upon what your setup currently is. Is it stock?
Define faster. More top end, low end torque, or you just want to beat that 67 Galaxie (lol).
This is great. You guys (or guy) ask the most vague question and expect a serious answer?
Are you also 12 years old? I see you and your buddy are having an argument about this: http://www.hotrodders.com/t66207.html
Old 07-18-2005, 07:14 PM
GalaxieRoller's Avatar
One o them people who can post
edge, I already told your ***** to shut the $%#^ up! What's your car run? 60.00s? I just wanted some ideas! I got time!
Old 07-18-2005, 07:35 PM
edge's Avatar
"I just wanted some ideas". You or 90lx, I thought he asked the question?
Give us a break. If you (or 90lx) really wanted some ideas you would have listed specific details on what you have and specifically what your goal(s) is. You have been posting pointless babble since you joined today (twice) specifically aimed at creating a stir. You start off by almost immediately calling another member an idiot. Your intentions are crystal clear and you have quickly proved you are nothing but a troll. Hopefully you'll get bored with this soon and stop messing up good technical threads.
Old 07-18-2005, 07:42 PM
90lx
this 90lx i have nothing to do with galaxieroller ijust wanted good help am 23 year not a young punk kid that kid is 12 and thinks he knows it all sorry for all of this
Old 07-18-2005, 07:50 PM
edge's Avatar
If that is the case, you will be better served by giving as much detail as you can (or know) on your current setup and what your goal is. Changing a cam is very much dependent upon the balance of your setup. Going bigger without properly matching to your heads, induction system, transmission (stall if an automatic), and rear end gear. Being that you have a 90LX, I assume it is fuel injected. If that is the case, then that factor alone will limit your cam choices.
Get more specific, starting with the title of your thread. Do this and you will get good responses. Too vague, and it is hard to help you. There are number of Mustang and Ford guys here and changing the title to something like "Need help with choosing new cam for Mustang LX" will help grab their attention.
Ed
Old 07-18-2005, 07:53 PM
thanks ed
thanks ed i will do that now
Old 07-18-2005, 08:03 PM
this 90lx i have nothing to do with galaxieroller ijust wanted good help am 23 year old 9th grade dropout not a young punk kid that kid is 12 and thinks he knows it all sorry for all of this
screw you Jay!!!!!
Old 07-18-2005, 08:13 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
classy.
Old 07-18-2005, 08:17 PM
Originally Posted by killerformula
classy.
you should see how messed-up mr.dropout's car is!:no egr, unknown timing, 225-50-r15 tires, chopped front springs, and he thinks it'll beat a mach 1!.
Old 07-18-2005, 08:27 PM
if so messed up
then why u over here every day wanting rides in it and dont show up here again the timing is at 20 deg smart guy with pill left in
Old 07-20-2005, 08:58 AM
kstagger's Avatar
check out the Ford Racing E303 camshaft - should work with your computer and give you some more power.
you might want a little more stall once you start getting more radical cams...
If you don't want to pull the camshaft out, you can try 1.7 rockers with your stock cam. There was a Car Craft article where they used a stock GT engine with AFR heads and the stock cam. With the 1.7 rockers, they pulled some good hp out of that 5.0
http://www.carcraft.com/techarticles/116_0307_ford/
Kevin
Old 07-20-2005, 05:17 PM
1982 SS's Avatar
Flamethrower
Last journal entry: More Cooling fan pictures.
My, quite a few posts regarding the negativity here. Why can't we all be friends, after all isn't that why we joind this forum in the first place? Get to know other people and learn something in the process? edge is right about the vague topic. If this is a personal vendetta between GalaxieRoller and 90lx, I would encourage them to settle somewhere else other than here.
Old 07-20-2005, 07:34 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
agreed. must I always play the role of pracekeeper? Well at least I have a sidekick now. *sort of jokingly*
Old 07-20-2005, 08:48 PM
edge's Avatar
That's going to very difficult considering they are one in the same. Two usernames, one troll.
This thread needs to be dumped too. Ed
Pontiac cam? Wmarden Engine 12 08-22-2010 08:09 AM
More issues....lets talk cam failure TurboS10 Engine 23 09-28-2004 11:51 AM
cam base circle vs. lobe lift question S10xGN Engine 4 09-19-2004 10:31 AM
Installed New Cam, CAR WONT Start/no Compression? sum87mustang Engine 4 10-27-2003 07:52 AM
289 cam change franklin289 Engine 0 04-22-2003 02:38 PM
