Cam Bearing - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2003, 08:24 PM
Post Cam Bearing
I have a 350 I'm putting a 465 lift 224 duration summit cam .The motor when I got it It was rebuild it has a factory cam do .I have to change the bearing .If not will it hold good oil presser.If there good will this cam where my bearing out. Thank's
Old 04-13-2003, 09:01 PM
BOBCRMAN@aol.com's Avatar
Post
your cam will not wear out your cam bearings, that wear is caused by lack of oil changes, excessive spring pressure(rare), general oil contamination, careless cam installation, low oil pressure. If the cam bearings look ok, have very few or no marks on them and don't look like the copper is showing, use them as is.
Old 04-14-2003, 06:04 PM
Post
Is there any thing I will have change like oil pump. I was told I have to change the blancer Is this true.
Old 04-14-2003, 07:42 PM
Post
no you don't have to change oil pump, you will have to remove the balancer to install cam but you can re install same balancer (put a speedy sleeve on it to keep the front seal from leaking)also replace the front seal.
