Cam Bearing Oil Hole - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2004, 09:28 PM
84 Z28 Convertible
While checking the main bearing clearance I notice that the cam bearing are not lined up with the main bearings. When I look through the main bearing oil hole I should be able to see through the cam bearing oil hole? As it stand now None of the holes for the cam bearing is align with the hole in the block to the main bearings. Whats going on here?
Old 03-05-2004, 10:35 PM
lluciano77's Avatar
Do the cam bearings have grooves on the backsides? In that case I don't think the position of the hole matters. It is only important that the correct cam bearing is in the proper place.
Old 03-05-2004, 11:39 PM
BOBCRMAN@aol.com's Avatar
If your motor is a small block chevy the oil holes will not be in line with the main bearing feed holes.
