A machine shop could do this for you for pretty cheap. $40 - $60? I think the going rate around here is around $80 - $85 for cam bearing install along with all the block plugs. That's including the cost of parts.
I have replaced several cam bearing sets, (while I worked in a shop) but always with the engine out of the car and the crank out of the engine . I would say it is possible to replace all of the cam bearings except the rear one with the engine still in the car. But would I advise replacing any less than the full set . No ! Unless all of the cam bearings have the same ID the cam is going to be constantly flexing, albeit only thousandths or ten thousandths, but nontheless flexing. Best bet is bring it to a machine shop and have all of the welch plugs replaced while you are at it . JMHO
My best advice is....unless you can tell that the cam bearings are completely worn out by rattling the cam up and down in its bore, leave the cam bearings alone. Do not vat the block in caustic material as it will eat the bearings. Not every engine build requires new cam bearings.
cam bearing removeal?
I guess I missed the point again? why would someone change cam bearing without rebuilding the engine? You rebuild or overhauling? What are you doing, and why?
tear it down and take a look. JMOCole |
I was planning on replacing the font one only during my cam removal the gear scrapped and grooved into it badly. The motor is still in cAr removed bumper and grill a local machine shopped said for 75 buck they would come and remove and replace front bearing? The third bearing has a small groove also but very minor, must it be removed also?
If the small groove in the third bearing is just a scratch and not into the steel shell I would just replace the front bearing and run it. As always this is just my opinion and what I would do. I assume you are installing a new cam so be sure to coat all the lobes with cam lube and oil the bearings and put the cam gear on the cam to make it easier to keep the cam centered in the bearings . If this is a flat tappet cam don't forget the zinc additive and use proper cam breakin procedure . There is a WIKI article on it . Allan
| Right cam for a 383? | atomicrockerdude | Engine | 23 | 11-02-2009 12:13 AM |
| Cam for a 455 olds, tips, or info wanted | littlehandegan | Engine | 7 | 09-07-2009 07:52 PM |
| Would this Isky Hydraullic roller cam work good for my combo | eric32 | Engine | 9 | 06-18-2009 04:36 PM |
| Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? | killerformula | Hotrodders' Lounge | 20 | 08-31-2008 05:12 PM |
| IGNITION and CAM TIMING | sum87mustang | Engine | 3 | 07-11-2003 07:52 PM |
