Cam bearing replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2008, 06:39 AM
How would you pull and replace the cam bearing without a puller ? this is a 92, 4.3 chevy bear block
Old 03-17-2008, 07:14 AM
Boy there is really no easy way to do it with out the right tools as the cam bearing housing bores in the middle of the blocks are smaller so what ever you use becareful.
Old 03-17-2008, 07:19 AM
nitro_baller4692's Avatar
floppers forever
go rent a cam bearing tool from the parts store,you will have to put down a deposit but you get it back.just do it right the first time
Old 03-18-2008, 08:09 AM
the only place I know that loads tools is auto zone they say they don't have a puller. there are no machine shop for about 30 miles
anyone know of a place in Kingsland Ga ?
Old 03-18-2008, 09:39 AM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
You could make your own I suppose but it would be time consuming, take a look at proform tools they have one for around $200 that is decent. Otherwise take it to your local machine shop and have them do it for 30 dollars. If you are doing it alot the tool is a good idea, If this is a "once in a great while" thing then just have a machinist do it.
Old 03-18-2008, 12:41 PM
Cam bearing installation is pretty touchy, even the pros have problems. This is best left up to a shop with tools and experience even if it 30 freeway minutes away by LA distance measurement.
Bogie
Old 03-18-2008, 05:43 PM
BOBCRMAN@aol.com's Avatar
To add an important technical note.. 4.3's use different cam bearings in blocks made in Tonawanda Ny. Than blocks made in Romulus Mi. One of the many "gotcha's" designed into 4.3's.. Look for a small "T" on the rear of the block near the rear seal attach area.
Old 03-19-2008, 05:34 AM
I was told the "T" was in front of the block I didn't look in back . The old cam look good the bearing are not real bad. could I clean them up and reuse them with out pulling them?
chewed cam bearings? ImRoyaltyInMyChevy Engine 38 03-17-2008 06:02 AM
Tri5 front wheel bearing replacement Stroker56 Suspension - Brakes - Steering 3 04-14-2006 05:36 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
Cam Bearing 70 nova Engine 3 04-14-2003 06:42 PM
Oddball Cam source? Biggarmike Engine 3 02-02-2003 10:52 AM
