Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - cam bearing tool, help
Old 01-11-2011, 08:23 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
Originally Posted by crussell85
Yes I know the cam bearings are different sizes, if the bearings are marked correctly and the installation sheet that the bearings came with is correct then I am on the right track for that. I just can't get the tool in place to install the outer bearings. I have tried to place the taper bushing inside of the engine in the cam tunnel but I can't get it to fit. I have tried it everywhere in the cam tunnel.
The one I made has no cone on the guide piece, that makes the piece small enough it can be put into the cam tunnel. You may need to have that cone cut off yours.
Looks like you are finding out some of the particularities of budget "home user" grade machine shop tools. They are always just a bit less quality and engineering. In your case, like several I have looked at in the years since I made my driver, the rod is just too short.
