cam bearings - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2009, 08:32 PM
The mobile view is crap
cam bearings
If a cam bearing has spun inside the engine will it affect oil coming up through the pushrods.
I have no oil coming up through the pushrods. All 3 plugs behind the timing cover are in, no oil coming out from back of engine. 60 psi of oil pressure. I am not getting any oil to the top of the engine at all. I have done the distributor prime thing for 15 minutes straight. Even if I wasn't rolling the engine while priming I should still get oil to just the one side right?
Old 08-23-2009, 09:09 PM
ericnova72's Avatar
More for Less Racer
Question #1 - If a cam bearing has spun, you can have lower oil pressure due to leaks around the bearing, but it won't affect lifter oiling as the center galley feeds the cam and rotating assembly and not the lifters, just the two outer galleys feed the lifters and valvetrain.
Question #2 - Not if the rear-most lifter is up the bore so that the oil band around the lifter body is no longer aligned with the oil galley hole. Oil pressure from the rear of the galley to the front is intermittent, not steady, due to the lifters moving up and down in each lifter bore and blocking the passage in turn.
Have you removed the rear lifter on each side and checked for oil flow into the lifter bore from the pressure oil passage while running the priming tool?? This is the first step in the chain to determine how far the oil is traveling (or not traveling) in the system.
Old 08-24-2009, 07:26 AM
Marcel
Last journal entry: Choo-choo town
valves not getting oil?
I had made a priming shaft from an old dist ( cut off the top which held the rotor button drove the pin from the cam gear and slid it off the shaft then from the housing and ground the teeth from the cam gear, take a little extra off to insure it clears the cam) I have a lathe an used it to cut the top off and turn the teeth off. It had oil pressure but didn't get oil to the valves. I took the old dist. housing and cut the top off just above the hold-down ring (with the shaft removed) and reinstall the shaft. (I marked the shaft at the top of the cut and removed the shaft and cut a groove around the shaft for a lock ring to hold the shaft in the housing.
Reinstalled the primer and lock it down and gave it a spin ( used the starter with the plugs out). After a min. or so I had oil to all the valves. I did rotate the crank while spinning the pump.
I don't know what it had to do with anything, but I'm thinking that the rings around the dist. housing (which I though were to stabilize the housing had something to do with the oil flow to the valves.
After about 5 Min's., I readjusted the valves.
hth.s
Old 08-24-2009, 06:46 PM
I removed all of the lifters and spun the priming tool while turning the engine over and felt no oil coming through the lifter oiling hole. If all of the lifters are removed should I drop oil pressure if everything was right? When I spin the priming tool I have 60 psi of oil pressure with or without lifters in place. I removed the timing chain cover and gears and I have oil running out around the front of the camshaft and crankshaft, it just kind of runs out, should it like splatter all over and make a mess everywhere without the timing cover in place? It just runs out the end of the shafts and back into the oil pan. Is there such a thing as a blocked passage from something and if so is there anywhere I can blow like 100 psi of air with a rubber tipped nozzle into the oil passages?
Would this Isky Hydraullic roller cam work good for my combo eric32 Engine 9 06-18-2009 04:36 PM
Cam Failure, oiling problem?? bsorbe Engine 13 04-09-2009 08:25 AM
CAM Bearings OHD Engine 4 10-26-2008 09:54 PM
split design cam bearings - help DHMag Engine 3 11-24-2005 04:16 PM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 07:52 PM
