cam bearings? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2010, 09:09 PM
JB Welder
cam bearings?
I have a stockish 80's amc 360 that doesn't have too much wear on a rebuild and I want to mill the heads a little and do a valve job while I swap intakes and carb. Would it be suicide to stick in a new cam and lifters without changing cam bearings?
Thanks for the advice.
Old 02-18-2010, 09:24 PM
327NUT's Avatar
No not at all, no different than when a guy just doe's a cam change. You say it's a fairly recent rebuild so it should be ok. You'll be able to get a feel for the clearance when you slide the cam in. Once the cam is all the way in it should turn with some interference due to the oil smeared on the cam but not too freely.....shouldn't be able to "spin" it.
Old 02-18-2010, 10:01 PM
ericnova72's Avatar
More for Less Racer
Considering the recent rebuild there would be no need to replace the cam bearings unless some sort of internal engine damage had occured and pumped the oil system full of metal particles. Cam bearings are a low wear item, usually very durable, no need to change them with the cam. You will be fine.
Would this Isky Hydraullic roller cam work good for my combo eric32 Engine 9 06-18-2009 04:36 PM
Cam Failure, oiling problem?? bsorbe Engine 13 04-09-2009 08:25 AM
CAM Bearings OHD Engine 4 10-26-2008 09:54 PM
I need cam help 355s10 Engine 5 03-16-2008 05:34 PM
split design cam bearings - help DHMag Engine 3 11-24-2005 04:16 PM
