Cam break in - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2012, 06:46 PM
Cam break in
Hey guys quick question. During cam break in I had a few things to fix during the break in period. So my question is, does each 5 minutes of run time go toward the overall 20 min needed to break in the cam or do you need 20 min straight.
John
Old 05-16-2012, 07:32 PM
Richiehd's Avatar
JS-70
20 minutes straight is better, thats why we say make sure everything is right. But 20 minutes total works too. Change oil and filter while oil is hot. Stay with an oil with zinc if you have a flat tappet cam.
Old 05-16-2012, 07:47 PM
Thank you for the quick answer. Do you do a oil change before seating the rings
Old 05-16-2012, 07:52 PM
Richiehd's Avatar
JS-70
Yes, after that 20 minutes breakin, change that oil and filter. Its full of grit from machining, assembly, ring and cam breakin.
Old 05-16-2012, 07:55 PM
Great thanks for the info.
John
Old 05-16-2012, 08:47 PM
Being the amateur I am, I always find myself fixing something with a cam break in lol. In the end I haven't had any mechanical issues that stemmed from it....yet
Old 05-17-2012, 05:07 AM
My problem turned out to be my fast efi was too lean making the headers glow red.
Old 05-17-2012, 06:28 PM
Richiehd's Avatar
JS-70
OUCH! Ihope you dont have the valves too tight.
Old 05-17-2012, 06:35 PM
no, once I adjusted the EFI settings she ran no problems at all never heating up at all.
Old 05-18-2012, 09:53 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
I have always heard and will probably abide by this but I always like to break an engine in on a known good carb. Intake gaskets are cheap enough.
Old 05-18-2012, 10:08 AM
1971BB427's Avatar
I try not to idle the engine at all during break in, but I have stopped them several times if needed. Best is 20 min. uninterrupted, but that's not possible if things go wrong. I haven't had issues by stopping either.
I change oil after the break in and a test/tune drive, then again at around 500 miles.
Old 05-18-2012, 05:01 PM
thank you for the info.
Old 05-19-2012, 03:55 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I would add more break in lubricant to the motor oil after the first oil and filter change, same as when the cam was first broken in. Using ZDDPlus, etc. or oil that contains sufficient additives for flat tappet cam break in will do fine. You don't need too much additives, either- just the recommended amounts. This may not be absolutely necessary but I consider it cheap insurance.
Old 05-19-2012, 05:06 AM
I have no problem doing that. What is your thought, it still needs more break in?
John
Old 05-19-2012, 08:20 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
John
If you have a total run time of at least 20 minutes, you're prolly OK. If you are the worrying type, give it another ten minutes =/> 2000 rpm w/o idling and call it good.
Cam Break-in - how soon? dhunt00c Engine 23 04-06-2008 07:40 PM
Cam Break In Canadian Charlie Engine 2 03-20-2006 04:57 PM
Cam Break in comet boy Engine 9 04-05-2005 08:04 AM
Synthetic for break in? What weight ? (engine and cam break in that is) sizemoremk Engine 5 08-14-2003 05:50 AM
Cam Break-in Rodrunner Engine 4 01-14-2003 01:12 AM
