Cam break in advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2009, 09:34 AM
done
Last journal entry: ...
Cam break in advice
Old 12-15-2009, 10:16 AM
Banned
Originally Posted by JohnBer
Will be installing a 305 duration, .590 lift cam in my 383. It is a flat tappet hydraulic and 1.6: roller rockers
Break in has me a bit concerned. Comp cams says leave out the inner springs and use their break in lube. After installing a few of the springs I figger'd out these things are STRONG. (bent my valve spring clamp, had to install gussets on it)
I do have a set of springs that are a little looser, and a set of stockers. Would one of these latter sets be good for the break in? Or would it be just a wasted effort. As it is i have to pop all the springs off once anyway . also, should i throw in a set of 1.5: rockers for cam break in?
Any input appreciated,
TIA
John
run 1.5 rockers, and if your springs with a little less pressure can take the lift of the cam then I would run those. I always say a good long prayer before starting up a new engine and have yet to have a cam failure. I also stay away from overly agressive cams...
Old 12-15-2009, 11:02 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
And they should know, right?
Yes- the cam specs and break-in recommendations are all based on 1.5:1 rocker ratio, unless otherwise indicated.
Would this Isky Hydraullic roller cam work good for my combo eric32 Engine 9 06-18-2009 05:36 PM
New Cam Advice 65Guera Engine 23 01-10-2007 12:14 PM
Advice with this cam? BMM Engine 7 11-26-2006 12:15 AM
sucessful cam break in- what oil to use ? fast68 Engine 8 11-21-2005 11:28 PM
Cam break in with duel springs 406chevelle Engine 23 01-15-2004 05:17 PM
