Cam break-in initial timing help on SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2008, 05:08 AM
v8hed's Avatar
AK427
As per thread title. I have a 355 SBC with Comp XE274 cam, Edelbrock 600cfm carb, Performer RPM intake and HEI ignition. I've provisionally turned the engine to 14* BTDC. Think this is about right? Want it to start in a hurry. I know about setting the timing with a dial-back light with the engine running, but I'm just after a good initial timing for that first start.
Thanks.
Old 08-25-2008, 07:22 AM
Guy Hiltz's Avatar
That should put you close enough to get it running.If thats a stock HEI distributor,I think they have around 22-24 degrees of advance built in,so that should put you around 36-38 total.
Guy
Old 08-25-2008, 12:03 PM
Last journal entry: Albany Oregon Show
Initial Timming
I know this is not timing, but if your engine gets a little warm/hot during break in I like to use a garden hose and run a gentle stream of cold water over the side tanks of your radiator. Thats of course if you have side tanks. Be careful not to get water on the core because it will pull through the radiator and spray everywhere. Make sure any water will drain out of your garage. Red hot headers is a good indication that your timing is not advanced enough or you are running to lean. I like to vary the rpm up about 500 every several minutes. Just give it a couple little reves once in a while.
Bob
Lunati cam and 305 sbc questions in a Frankenstein low budget rodder Engine 13 06-30-2009 04:55 AM
Cam Bearings and Core Plugs (SBC 350)89 gandl2123 Engine 15 03-26-2007 03:06 AM
350 chevy timing tiresmoke55 Engine 7 01-14-2006 10:55 PM
SBC Ignition Timing snod83 Engine 1 04-19-2004 04:42 PM
retarding cam timing fiscus Engine 9 01-09-2004 02:18 AM
