cam break in oil change - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2009, 01:53 PM
jafroyd's Avatar
I just put a new comp cams k-kit in my 327. I changed the oil and filter before break in. Is it absolutely necessary to change it immediately after break in? I've taken it out for a couple of road tests but nothing major.
Old 04-13-2009, 02:08 PM
BackYardRacer
i would have changed the oil after the cam was broke in and after another 500 to a 1000 miles when you brake in a cam you end up with metal in your oil and oil is cheap comperd to tearing down engine and replaceing ring bearing and who knows what ells because you didnt spend 20 to 30 on oil and filter
Old 04-13-2009, 06:26 PM
The thing that sometimes happens is with filters where guys are not running the bypass valve, the break in paste can plug up the filter and if it's an un-bypassed continuous flow and it gets plugged, you're buying a new engine.
Aside from that, if the cam and lifters didn't fail during break in and dump a ton of metal shavings into the oil, there's no reason to immediately do an oil and filter change, the filter change being the more important of the two. At this point just to be sure you're getting rid of trapped moly and any shavings. You'll get some metal at break-in but it shouldn't be more than a very light metallic sheen floating on the oil.
Bogie
Cam Bearing oil hole alignment morenoer Engine 3 04-06-2009 12:55 PM
Cam break-in and zinc Frisco Engine 34 03-13-2007 08:22 PM
A little humor Kevin45 Hotrodders' Lounge 8 10-21-2004 12:47 PM
First oil change, what to look for? killerformula Engine 7 07-18-2004 12:49 AM
question on cam & oil pump install chev 350 solowookie Engine 16 04-03-2002 04:25 PM
