Cam break in...What do you guys do? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2012, 02:52 AM
thinwhiteduke's Avatar
Living In The Past
Hi*
I have a 355 sbc with 294S comp cam (solid f/tappet) The specs call for .022" lash hot.*
The engine is all new, fresh valve train, heads , block , pistons etc*
I need to break the cam in, *( I am using the ZDDP additive )*
My question is what do you guys do as far as valve lash 'cold' clearances are concerned. Should I *set the lash at say .020" cold to allow for block expansion and wear during break in or set at .022" cold and then shut the engine down once hot and readjust the lash? And then continue with the 30 min break in?*
I am using the lifters with the little holes in them.*
If you need any more info, please ask.*
Thanks heeps!
Duke
Old 05-11-2012, 06:16 AM
engineczar's Avatar
If it's got cast iron heads just set them to spec and do your break in. Don't shut it down to reset them until the 20 minutes or so is up. The extra couple of thou of clearance won't mean anything to the break in. If it's aluminum heads go .006 tighter on the clearance.
BSE Racing Engines
Old 05-11-2012, 12:58 PM
Living In The Past
Thanks guys, yeah cast sportsman two heads. F-BIRD'88 I have the dissy set to 10deg max centrifugal adv, all in by 3000rpm, (from a previous build) Do you think 24deg static timing will be enough? I have 750 Holley with all throttle transfer slots set open to .020" and 4.5 power valve.
Duke
Old 05-11-2012, 01:51 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Originally Posted by F-BIRD'88
I see you tout this stuff all the time. They have many products, which one do you suggest? Looks like they have a break in formula and an engine oil supplement. Do you use both or just the break in?
Old 05-11-2012, 06:05 PM
Richiehd's Avatar
JS-70
You can use a set of 1.3 rockers for break in, then you dont have to pull the springs. What size studs are you using? **************
Last edited by 68NovaSS; 05-11-2012 at 06:24 PM. Reason: Classified ad. Please use the Hotrodders Classifieds for classified ads.
Old 05-12-2012, 03:56 PM
Living In The Past
Studs are 7/16". Those break in rockers are too damn expensive for me, might be ok if a few mates chipped in and we shared em round the (family).
I just took the inner springs out using the rope trick, actually I used thin plastic tubing , feed it in at TDC swaped out the springs using an $8 hand leaver type compresser and then pulled it out, 'twas simple. Easy on the engine stand, might be a different story in the car! , my back is getting a bit dodgy..
Duke
Old 05-12-2012, 04:13 PM
Living In The Past
The 24 initial 10deg advance curve will be the minimum you will need.
It will run real sweet with locked out timing. I recomend you simply lock out the mechanical advance for this 294s cam....Try it
(auto transmission.)
reguardless. If you have vacuum advance use it too.
Vacuum advance needs to be limited to 10-12deg at high manifold vacuum
part throttle cruise. Like on the hiway.
Yeah it's auto trans, I like the sound of it running 'real sweet' lol , that's the plan!! Ill try it with the locked out timing..
If I want to incorporate an isolation switch to kill the spark for easy hot start cranking, do I simply put an interruption switch in on the low voltage side of the coil? Is that where you put it? The dissy is single points.
Thanks for the tip on just changing the filter after cam break in, that sounds good to me - I can't afford to throw any money away ATM
Duke
Old 05-13-2012, 04:20 AM
Living In The Past
Ya that is where the switch would go but surely you are not still using ignition points. You can up grade to good effect using pretty much any CD box. Can be triggered by points. Surely you can dig up A GM HEI distributor to use instead of points.
Make sure the GM starter motor rear support bracket/brace is installed on your starter.
Yeah, got the starter bracket. My budget is right down to the bone ATM with this, but an upgraded ignition system is first on the list in the future. Ill try to pick up GM HEI meantime if I can get one for fifty bucks or so, if it's gonna be THAT much better.
Thanks so much for our help.
Duke
Cam Break-in - how soon? dhunt00c Engine 23 04-06-2008 07:40 PM
Cam break-in? Steves66 Engine 1 03-06-2006 08:31 AM
Cam break in dutch paul Engine 6 09-03-2005 03:31 AM
Synthetic for break in? What weight ? (engine and cam break in that is) sizemoremk Engine 5 08-14-2003 05:50 AM
