I would use th GM E.O.S. lube along with what you are doing to ensure a trouble free break-iin-
I also have interest here since last year my XE268 Comp Cam wiped within 20 minutes and took out all the crank bearings. This is the second XE268 I've lost in the last three years. After having the block cleaned and the crank ground, I'll refire it this summer.
I have recently saw "diesel oil" for sale at AZ or Advance. Would this sub for the Shell Rotella? Also, I recently read that the Comp Cam techs told a guy that their red stuff is only good for a week after application. Comments? |
You had me goin' there for a minute, I thought maybe GM stopped makin' the stuff, but a search at Scoggin-Dickey (www.sdpc2000.com) turned up the pour-in lube.....
http://www.sdparts.com/product/10523...6ozBottle.aspx |
I used the comp cams lube that came with cam and a smear of moly lube on bottom of the lifters. I put a bottle of EOS in the oil itself. I think you would want it to mix up well with oil so that way the non zinc(or less zinc anyway) oil will have less of a damaging effect on the cam. I also used the shell rotella 15/40. STP also makes a very think oil supplement with ZDDP. I stir in a LITTLE bit (maybe an ounce tops) with every gallon of oil I use. I am not sure how much of an overall effect it as but it helped me sleep at night after i did the break in.
I had to pull top half of motor due to improper torque of the heads/head gasket causing a coolant leak into oil. While i had the manifold off I checked the bottom of the lifters and all seems to be well. |
All Diesel Engine Oils are NOT the same-and now, with the new Tier III Diesel regs going into effect, I'm not certain that any of those will help now. I think I would break-in with something like Valvoline Racing Oil (I've heard that it still has the Zinc)-anybody else know? In my Project the first thing I wanted to do was build the Engine, but I talked to a Tech at Childs and Albert and he recommended to wait until I was close to done and do the Engine last, so that is what I'm doing-his reasoning? That the Cam Lube and such would drip off of the Camshaft-now, I know what some of you are going to say (I think!)-what abut the Crate Engines out there sitting on the Shelf that may have been built some time ago? I don't have the answer, but I do agree with the Child's and Albert's rationale- |
Good info! Thanks for the link. I'll go back to the dealer tomorrow.What I asked for today was GM EOS but gave the part #12345501. That part number is for the 4 fl.oz. bottle of Camshaft & Lifter prelube. It cost right at $7.00 for the 4 oz. bottle. Your link shows part #1052367 and claims it to be a pour in additive and/or an assembly lube. I'll pour it in with the Shell Rotella oil and prime the system good before firing it up. It will be a month or so before I fire the engine, but I will post the results. To MI2600, I don't know if all diesel oil has zinc in it or not. Perhaps one of the others here will know. |
Along with many others, I use a set of worn-out stock valve springs for break-in, then change them out with shop air and a Manley spring compressor.
A quicker and easier way would be to use the springs that you will run with the cam and use a reduced-ratio rocker arm for break-in, changing them out to the full ratio after break-in. I was just searching for them and found part # 1112-16 in Compcams catalog, 1.2 ratio. I'm told that Crower makes them too. I priced the Comps in the Jegs catalog and they are....ready for this....$422. Am I the only guy who thinks it's high time someone produced some stamped steel 1.2 rockers that won't break the bank? |
The old claim was that Rotella T had .14 ZDDP content - with the new CJ+ ratings and such I highly doubt the new stuff still has it. On the flip side - I had a diesel engine that never seemed to like Rotella and I started using the "Coastal" 15-40 diesel fleet oil from Advance and AutoZone. Engine likes this stuff and price is a tad cheaper then Rotella. Anyways - I was looking at that and noticed it wasn't CJ+ - still the old CJ rating - Warren Unilube produces it, I called up their number off their website and amazingly a friendly tech pulled the information sheets for it and helped me out saying it is rated at a .141 ZDDP content. With that in mind that is sitting in my fresh engine waiting to be broken in - cross my fingers!! The problem is that oil ratings are often changing - you have to watch the ratings even on the same product on the shelf - recently I was in Sears and noticed some of their house brand stuff was SL and some was SM - just keep your eyes open.
Does anyone have any fact sheets on what STP additive contains? Been curious and I could never find that info. |
Posted by Koolaid:
"Does anyone have any fact sheets on what STP additive contains? Been curious and I could never find that info." Years ago, I attended a school at the Quaker State refinery in Oil City, Pennsylvania. They instructed us that STP is a polymer that does little else but increase the viscosity index of the oil. |
I would recommend using Crane moly paste on the bottoms of the lifters, on the lobes,on the distributor gear and on the fuel pump cam lobe. I would use GM EOS on the initial oil fill and Shell Rotella (older recipe) or equivalent.
tom |
Think of this. 300# springs over the nose x 1.5 rocker ratio = 450# down pressure, which was claimed to be 30,000+ psi on the lifter/lobe contact area. 300# x 1.2 rockers = 360# down pressure. Not a big difference, but significant. According to Billy Godbolt of CompCams, newer cam lobes are being ground with a little more "side angle" and the newer lifter faces are being ground on a radius of down towards 60 feet instead of the old 100 feet. (yes feet) This is to make the lifter turn better, at the expense of mileage longevity. But the new contact pressure is estimated to be 50,000 psi because the contact area is smaller. YIKES. I use 200# springs @ .500 200 x 1.5 = 300# is not that much different. Big difference is that the lobe heel and ramp are much less pressure. These springs only sit about 80# closed @ 1.75. Looking through all the stuff on Comps web site, there is recommendations for 45 to 60 minutes at about 3000 rpm. I have used 200# springs and 45 minutes for years. I haven't lost a cam yet. And YES it is a pain to change springs. But it is a bigger pain to tear the engine down and clean it and replace the cam and all the other stuff. I also try to get 4 hours on the engine keeping it under 3500 rpm before installing the inner springs, or switching out the 200# to the recommended springs. Rotella T and EOS. Mobil 1 synthetic later. Also if you cruise the net, you will find major engine builders that say use MOLY, some say NO, it is to abrasive. Do what your cam manufacturer recommends always. |
Well I gotta ask...
Why is it then that GM has used synthetic oil (namely Mobil 1) for break in...? Now dont go say well its roller lifters because that just dont cut it for the ring side of things...? I mean if its ok for the ring breakin then why not for cam break in...? Anti scuff is synthetic`s main property so hey what would be the issue with a new hyd cam build...? My .02
http://www.thegsresources.com/garage/gs_additive.htm
Scroll down aways to "The Zinc question". Some interesting stuff. They say the penzoil and valvoline racing oils contain the healthiest of zinc content. Shell rotella usually is at .141, the racing oils claim .20. Its not the gospel but its a little backround on all the oil additives. |
