-   -   Cam button (http://www.hotrodders.com/forum/cam-button-75099.html)
GCD1962 11-30-2005 08:10 PM
Cam button
Getting ready to put the 70 LT-1 engine back in the '62 Corvette. I bought a cloyes true roller set and a Jeg's Alum timing cover. There seems to be a fit problem using a cam buttom (.640 length). My question is, the cam is the stock 70 LT-1 mechanical cam and lifters. Do I really need the cam button? If so, can I shave a little off the back to gain enough clearance to make it fit? how much clearance should it have.
poncho62 11-30-2005 08:18 PM
Maybe the cover is designed that it doesn't need the button. The stock engines didn't use a button.
Moving to engine forum.....
RPMs 11-30-2005 08:52 PM
You only need a cam button with a roller cam.
GCD1962 11-30-2005 09:00 PM
I've read that, but the engine (350 LT-1, 370 HP) came with a cam button, roller type in the stock gm nylon gear. Timing cover (stock GM) had a plate brazed in for the button. With a solid lifter cam does the rotation tend to push the cam forward or back?
johnsongrass1 11-30-2005 09:47 PM
Fla tappets will center the cam. No need for a button. You might verify the cam gear has bearing behind it. I don't knw if those blocks have the thrust face machined in or not.
RPMs 12-01-2005 07:47 AM
I used to work in a performance machine shop. What you are describing has been added it is not factory stuff.
454C10 12-01-2005 12:36 PM
Flat tappets push the cam towards the rear of the engine.
No need for a cam button.
bracketeer 12-01-2005 01:06 PM
A cam button is not necessary. BBs have more of a tendancy to move than a SB. If you use a Comp nylon button, it can be shaved to any length. Shave it to zero movement without a timing cover gasket. Then installing the gasket will give it about .010 clearance.
