Cam button
Getting ready to put the 70 LT-1 engine back in the '62 Corvette. I bought a cloyes true roller set and a Jeg's Alum timing cover. There seems to be a fit problem using a cam buttom (.640 length). My question is, the cam is the stock 70 LT-1 mechanical cam and lifters. Do I really need the cam button? If so, can I shave a little off the back to gain enough clearance to make it fit? how much clearance should it have.
Maybe the cover is designed that it doesn't need the button. The stock engines didn't use a button.
Moving to engine forum.....
Ontario Rodders |
You only need a cam button with a roller cam.
I used to work in a performance machine shop. What you are describing has been added it is not factory stuff.
A cam button is not necessary. BBs have more of a tendancy to move than a SB. If you use a Comp nylon button, it can be shaved to any length. Shave it to zero movement without a timing cover gasket. Then installing the gasket will give it about .010 clearance.
| 350 bored .060 over... XE268 cam, I didn't put a CAM BUTTON IN!!! | Dizturbed One | Engine | 12 | 08-08-2010 08:50 AM |
| Please Critique Cam and Combo for 383 | Chevy21 | Engine | 7 | 04-01-2005 12:50 AM |
| flattened cam | 383vette | Engine | 7 | 05-04-2004 10:02 AM |
| CAM BUTTON OR NOT | MIKE T | Engine | 3 | 02-08-2003 04:26 PM |
| cam selection | chevyelc81 | Engine | 9 | 09-17-2002 06:41 AM |
