cam button - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2006, 02:20 PM
KNIGHT07731's Avatar
cam button
i installed a new cam last week and forgot to replace the button, how long can i run the engine before it fails
Old 09-15-2006, 02:35 PM
You can run it as long as you want before it fails. It won't run after that....
Old 09-15-2006, 03:10 PM
327NUT's Avatar
That was a good one.......but if you think its going to fail....WHY in the world would you even start it ???????????? I,m assuming its a hyd. roller, pull the front cover and fix it.
Old 09-15-2006, 04:54 PM
nitro_baller4692's Avatar
floppers forever
yeah!don't wipe out a cam or lifter over laziness.could cause more time and money,from the sounds of it you don't have or want to spend either.
just fix it right so you don't cry about it later.
Old 09-15-2006, 06:59 PM
Guy Hiltz's Avatar
cam button
Just to give you on idea,the old Crane solid roller cam in my LS-6 big block ran for 15-16 years,then a lifter exploded and ruined the cam,but a cam button/thrust washer are good to have if you are running roller cams.
Old 09-15-2006, 11:15 PM
Well the last roller cam and lifters I bought cost about 700 dollars. If that cam walks at all its gonna wipe them both out in no time...
Old 09-16-2006, 04:37 AM
cam button
i haven't started the motor as yet, just wondering if anyone ever had an experience where the forgot the button, and ran the motor
onovakind67 (funny guy)
350 bored .060 over... XE268 cam, I didn't put a CAM BUTTON IN!!! Dizturbed One Engine 12 08-08-2010 08:50 AM
flattened cam 383vette Engine 7 05-04-2004 10:02 AM
The cam mistake is running, well, kinda! Jmark Engine 12 12-31-2003 12:49 AM
another cam ouestion...ie...cam timing VETTE GUY Engine 0 06-28-2003 11:29 AM
CAM BUTTON OR NOT MIKE T Engine 3 02-08-2003 04:26 PM
