cam button cover questions. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2013, 10:10 PM
I cant hardly find any info on what i need lately apparently. Ok so from what i'm reading it seems like a nylon cam button is the best one since the roller button can come apart and fill your engine with the rollers? I would just buy a cloyes quick button cover but since the block I have is a raised cam block i'm doubting that would work. (i assume its for a standard cam location). I would like to have a 2 piece cover but i guess its not a big deal... My other question would be since the end play requires you to torque down the cover and gasket etc. to get the correct end play reading wouldn't that screw up your gasket you were planning on using?
Old 05-28-2013, 11:07 PM
The gasket will bwe fine if you put it in dry or just stick it to the cover and use no sealer on the block side for the mock up.
Old 05-29-2013, 08:00 AM
is the nylon cam button a better choice between the two?
Old 05-29-2013, 02:24 PM
techinspector1's Avatar
Wiki Edits: 326
Simpler is better.
Old 05-29-2013, 03:29 PM
That's what i thought. thank you. now to figure out the end play
Cam button help Chevyjeepster Engine 8 01-22-2012 04:46 AM
Thrust button stopping timing cover being installed v8hed Engine 19 03-09-2011 05:23 PM
350 bored .060 over... XE268 cam, I didn't put a CAM BUTTON IN!!! Dizturbed One Engine 12 08-08-2010 08:50 AM
Need some help on timing cover and cam button combo. eric32 Engine 7 07-27-2009 10:47 AM
Roller Cam Install - Cam Button & Timing Cover Help leejoy Engine 9 12-01-2007 04:28 PM
