Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam button help
Thread: Cam button help
Old 01-19-2012, 09:47 PM
tjet tjet is offline
You don't need to use a button on a flat tappet cam (roller cams need a button though)
The problem I had was with the dual idler gears. They want to come forward.
If you are set on gear drive, the Milodon 3 gear is a better setup
