-   -   Cam button help (http://www.hotrodders.com/forum/cam-button-help-212847.html)
Chevyjeepster 01-19-2012 06:00 PM
Cam button help
I have a gear drive on a SBC, it's one of those low cost eBay jobs. I had to cut down the button, not a good move! How do you know what length to get? The button I had the timing kicked out about 1/4" or so. So now I no cutting down a roller button doesn't work. Someone please tell the easiest way to get this done and don't beat me up......too bad!
Thanks Jim
birkey 01-19-2012 07:06 PM
i'm not too experienced but maybe you could use a piece of clay.
1932bantam 01-19-2012 09:39 PM
throw the gear drive in the trash, buy a 30.00 timing chain and save yourself alot of headaches. I seen 2 engines get trashed last year when they came apart and they will.
tjet 01-19-2012 09:47 PM
You don't need to use a button on a flat tappet cam (roller cams need a button though)
The problem I had was with the dual idler gears. They want to come forward.
If you are set on gear drive, the Milodon 3 gear is a better setup
engineczar 01-20-2012 10:00 AM
I'm not going to comment on whether or not you need a button. On engines that I put a button on I find you need to use a cover with raised ribs on them to get the button to clear.
Similar to this one:
http://www.hotrodders.com/gallery/da...r-21-900_w.jpg
Standard covers are set in too much.
Landshark928 01-20-2012 11:12 AM
Easiest way to solve this is to use the Cloyes billet cover with the adjustable cam button. About $125. Looks great, doesn't flex and allows fine adjustment of Cam button lash to prevent walking.
I use it and it works well. Set it to zero lash cold and when things warm up it's set. It has an adjustable roller button built in. Here's what it looks like before installing. As a side benefit it allows cam changes with out pulling the balancer or pan.
http://i1233.photobucket.com/albums/...e/IMAG0263.jpg
engineczar 01-20-2012 11:22 AM
I build a lot of small block SuperModifieds here in the Northeast and use the Cloyes billet cover on all of them. Nice piece if you can afford them. Obviously you mean cam timing changes and not cam changes.
Chevyjeepster 01-21-2012 07:07 PM
Gear drive
1932 Bantam, I did just that! Pain in the neck I don't need. I thought I do something different because I always used chains never a gear. Never again lesson learned.
1932bantam 01-22-2012 04:46 AM
GOOD MOVE! :sweat:
