CAM BUTTON OR NOT - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2003, 03:51 PM
Post CAM BUTTON OR NOT
DOES MY MILD SMALL BLOCK CHEVY NEED A CAM BUTTON
WITH A COMP CAMS .470 LIFT?
Old 02-08-2003, 03:55 PM
BOBCRMAN@aol.com's Avatar
Post
flat tappet cams do not need cam buttons, they are for rollers.
Old 02-08-2003, 04:16 PM
The Vandal's Avatar
Engine Tech Addict
Post
A flat tappet cam (hydraulic or roller) is not actually flat. It is ground this way to spin the lifter and to push the cam back in the block. Because you can't spin a roller lifter, the roller cam is ground flat and this allows it to walk back and forth in the block causing erratic ignition timing and possibly rubbing against the timing chain cover. That's why you use a button.
The Vandal
Old 02-08-2003, 04:26 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
Plus the action of turning the oil pump holds'er in place. My gear drive (don't start Bob ) came with a button, so I used it with my flat tappet cam, what the hell. You don't need it though. Oh yeah the instructions that came with my gear drive said to use the button no matter what, but I would have either way, what the hell.
[ February 08, 2003: Message edited by: BstMech ]</p>
