Cam: Calculate LCA (cam°) from lobe center angles (crank°)? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2004, 07:00 PM
May be a dumb question but...
Can you take the two lobe centerline angles in crank °, sum them then divide by 2 and arrive at the centerline or separation angle in cam °?
E.g. let's say a cam has:
intake lobe centerline @ 108° crank
exhaust lobe centerline @ 116° crank
and you don't know what the LCA is...
LCA = (108+116)/2 = 112°?
thanks for the sanity check!
Old 09-14-2004, 07:29 PM
lluciano77's Avatar
That is the correct way to find lobe sep.
Old 09-14-2004, 08:28 PM
Thanks! I've been doing it but wasn't positive it was correct.
