Cam calculator - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2007, 11:50 PM
strummin67's Avatar
Violating consensual reality
Last journal entry: It tows!
Cam calculator-Is this correct??
I'm curious as to what cam duration I have either advertised or at .050. I have a 194 Chevy 6 that I'm going to assume was rebuilt with an original (or close) cam. The service manual lists the timing as:
Intake Opens BTC 34*
Closes ABC 86*
Exhaust Opens BBC 68*
Closes ATC 52*
This is the calculator I'm using
http://www.wallaceracing.com/camcalc.php
It says:
Your cam has an Overlap of 86.00 degrees and has in Intake Duration of 300.00 degrees.
The Exhaust Duration is 300.00 degrees.
The Inlet Cam has an Installed Centerline of 116.00 degrees ATDC.
The exhaust cam has an Installed Centerline of 98.00 degrees BTDC.
Are these numbers anywhere near correct? Thanks.
Strummin
Old 02-01-2007, 01:09 PM
strummin67's Avatar
I checked the calculator with another cam I had the numbers for and it was correct. I think my manual measured from a different starting point. Thanks.
Strummin
Old 02-01-2007, 01:26 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Did you ever have de-ja-vu ?????
Old 02-01-2007, 03:05 PM
strummin67's Avatar
I originally posted the question here first but got no responses...until today.
Pontiac cam? Wmarden Engine 12 08-22-2010 08:09 AM
Is it possible to degree an unknown cam? Scrumgees Engine 4 03-18-2006 11:50 AM
87 octane engine cam swap? 71C10 Engine 6 01-20-2006 10:50 PM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 01:11 PM
More issues....lets talk cam failure TurboS10 Engine 23 09-28-2004 11:51 AM
