Cam ? Cant find # or manufacturer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2014, 03:17 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
I pulled a cam out of a 74 Stingray small block, the #s are 1Z068 and a small 30P off to the side or it could be #1Zo68 ( Zero or O?) I did a Google search and can't find it? Is anyone familiar with this # and can give me a manufacturer or specs? I'm scratching my head
Jester
Old 04-24-2014, 03:32 PM
ericnova72's Avatar
More for Less Racer
Sounds like maybe stock or old GM performance over the counter maybe, they would only be identified by the color of paint stripe between a few of the lobes when new....won't have I.D. #'s like aftermarket cams.
Take a pair of calipers and get approximate lobe lift, would be a place to start looking.
Old 04-24-2014, 06:04 PM
eric:
LOL There are no lobes LOL its a flat tappet cam (really flat tappets and lobes now LOL) ,And no color code I checked it over good, Its supposed to be an aftermarket? The shaft has 010 between the lobes! The 1Z068 and the 30P is on the rear butt end of the cam like the comp cams and others. If I knew the specs it would save me time I could easily match a new one to the rest of the engine geometry and torque convertor and gears, The new owner Knows nothing about the car but it has low 12s and high 11 sec 1/4 mile time slips in the glove compartment! The heads are aluminum (cheepos) no identification or #s on them except a stamped "W" on the ends! I figure the parts were bought on an Ebay rip off store!!
I'm just taking a chance that someone on our site might recognize the Number LOL
Jester
Old 04-24-2014, 09:11 PM
ericnova72's Avatar
More for Less Racer
Are the lifters hydraulic, or solid??
Not a pair of intake/exhaust lobes left to even get a lift measurement from??
Old 04-24-2014, 10:43 PM
techinspector1's Avatar
Wiki Edits: 326
Have you looked on the rear face for stampings.
Old 04-24-2014, 10:44 PM
Hydraulic, there is nothing left to get a good measurement off of, most of the lobes are almost perfectly round only a few have any lift at all LOL two lifters had no bottoms and 4 lifters the cheap clips popped out and the tops (push rod seats) were gone laying in the valley and 4 bent push rods!!! It has roller rockers but the wrong geometry and the valve tips look like mushrooms and the edges are flaking off! Its just a botched build from the beginning He paid 2000 for the Vette and thought it was a head gasket or intake gasket because it had water in the oil and wouldn't run LOL I tore it down and found an intake gasket leaked underneath at the water crossover. The electric fan didn't work and the electric water pump had a hole wore through it because the big crank damper was rubbing against it!! Pulled the door panels to see why the windows didn't work and the doors were gutted !!! A 2by4 in each door was holding the windows up, 1 day working on it and it keeps getting worse the deeper I get into it
The guy is a Millionair (no exageration) he also pays me good!! But just won't spend a penny beyond that if it would save his life! He buys Ebay crap!
Jester
Old 04-24-2014, 10:53 PM
Wiki Edits: 326
That's how you become a millionaire.
Old 04-24-2014, 10:54 PM
Tech:
Yes, The whole cam has no markings or color code except for what I stated above stamped on the butt of the cam 1Z068 and a smaller lettered 30P stamped on it and an 010 between the lobes about half way up ! And I would rather be MIDDLE CLASS LOL!!!
Jester
Old 04-24-2014, 10:56 PM
ericnova72's Avatar
More for Less Racer
Wow, never even heard of or seen one run far enough to ruin all the lobes...what a mess. Sounds like a real "engineer" put that one together. Have fun.
Pics of the carnage would be cool if you got them....
The Following User Says Thank You to ericnova72 For This Useful Post:
techinspector1 (04-24-2014)
Old 04-24-2014, 11:03 PM
Wiki Edits: 326
Yeah, for sure, I've never seen a cam with all the lobes ground off.
Old 04-24-2014, 11:05 PM
Wiki Edits: 326
And I would rather be MIDDLE CLASS LOL!!! Jester
Achieving middle class is quite an accomplishment in today's world.
Old 04-25-2014, 12:22 AM
Its the worst cam I ever saw I don't see how it ran long enough to do that much damage!!!!!!! Unless it was running and all the lobes were wearing out at once LOL till it just wouldn't open any valves at all enough to run and Who Knows ????
It looks like they put flat tappets on a roller cam LOL there is no peek on any lobe they are flattened right out except for the ones that are ground away to nothing LOL
I took my camera and was going to take pics because the car looks good cosmetically but changed my mind LOL once I got into it! And yes its the worst cam I ever saw and the worst cobbled build!! it could be a sample of everything you can do wrong when building an engine LOL they used stock bolts for the aluminum heads and the heads of the bolts when torqued cut deep into the aluminum. The head gaskets were stock (not for aluminum heads) The engine was built 1 year ago by 2 guys whos rep in that area is good among locals there but they don't know what the cam is either LOL I asked!! The things the old owner said were in the engine talking to people turn out to be down right fantasys now that its apart! It must have been the old engine that ran the 12s and 11s? I just can't imagine this engine ran that well It has a 78 to 82 350 truck block thats been welded between the cylinders on the deck but never decked at a machine shop it looks like the welds were hand filed and then it was bored .030 over, the damper was beat to hell with a sledge or big hammer right where the pulleys bolt on and the crank snout is so grooved and scared like with a chisel that the damper was packed with blue silicone sealer to stop oil from running out the end of the damper if the bolt was removed LoL ! The owner just wants the top end put back together so it will run instead of letting me pull and go through the whole engine! I'm ashamed to say this on these pages but that's what I'll do for him! You should have seen the metal I pulled out of the galleys and pan and valley with magnets!! You could forge another BLOCK out of them and the pieces of the lifters I found!!! LOL I did flush all the galleys out with kerosene and long galley brushes and did the same with all areas of the block I could reach and flushed out the pan, Pressure oiled the galleys and put oil in all the cylinders installed a new oil filter (FULL) and
Primed the block with the oil pump and an old cam and lifters installed for the time being that I had, While turning the crank! that's the best I can Do without pulling the engine! Hopefully that flushed most of the metal particles (looked like graphite) out! I told the owner that the bearing inserts were probably bad but he wants to take the chance LOL SOME people you just can't explain things too
He has made me so MAD I want to teach him a LESSON I told him all the things that Metal has probably damaged in the engine , but he thinks it will be ok, now this thing will make me out a LIEer LOL and run great With just the top end done and what little I did to clean the block (YOU watch and see) LOL
Its funny how now that I'm retired
I put my principles to the side to do this job ( but I can use the cash) and I'm up front with the owner every step of the way on what should be done (right) and the downfalls of my doing it his way!!!! (wrong)
Jester
Old 04-25-2014, 06:36 AM
Painted Jester, been down the road you are on with this mess. In retrospect...both parties are money motivated only. Was me getting paid and wanting to do the repair correctly spending the money to do things right but then having to compromise my integrity to satisfy the owners denial that things will be ok and wanting to save money and get lucky. It did not turn out so good for the owner as I was correct in what was going to happen shortly with the thing. Bad thing about it all was the hard feelings over the mess between the 2 of us. I ended up being married to the mess to help out and him being upset thinking I did my job poorly. I should have just given the whole mess back to him when he decided to go the bad route on the project. I learned my lesson back then on things like this. I do not compromise my integrity for anyone these days....I just say my piece, let the chips and decisions fall where they may and then take it from there. The only area I do (very rarely do it any more) what you are doing here is with myself because then all I have to do is answer to my own stupidity.
I would seriously hand all the crap back to the guy and say, "If this is how you want to proceed with this build, I want nothing to do with it. I want no hard feelings to come between us over this stuff."
Old 04-25-2014, 11:09 AM
I wonder if its a regrind and they took all the case depth out?
Old 04-25-2014, 11:35 AM
steeny: Your last pic posted is my old time friends car!!! (Joey) LOL
Jester
trying to find out what this cam is gaurdian101 Engine 1 09-03-2012 11:06 AM
Need to find Air shocks manufacturer Ratoflic Suspension - Brakes - Steering 2 08-27-2010 04:55 PM
Need to find the right cam BIGWISEXY Engine 17 05-23-2009 04:51 AM
Need help cant find cam card bracketracer Engine 2 04-21-2009 06:40 PM
