cam change - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2002, 07:07 PM
Post cam change
what is a good cam to run with a tunnel rammed 377 cu.in street strip engine?
Old 12-12-2002, 08:10 PM
BOBCRMAN@aol.com's Avatar
Post
what heads? what carbs? auto or stick? rear end gear? tire size? car weight? got to know to get thw right stuff
Old 12-13-2002, 05:48 AM
DoubleVision's Avatar
Post
377 as in a standard bore 350 with a 400 crank? or a 40 over 400 with a 350 crank? if it`s a 350 with a 400 crank why run a tunnell ram? these are more torque engines than revvers. if the opposite a tunnell ram would be right at home. more Info please.
Old 12-13-2002, 06:38 PM
Post
377 being a 400 with 350 crank and rods dome pistons forged world product heads 72cc straight plug 4.155 bore edellbrock tunnel ram with i think is just a cool set up with 450's 50cc pumps gear drive 350 turbo trans b&m 3000 stall gm 8.5 rear 4.56 loc-right 28" bfg tires. i have a comp cam 305 mag 525 lift right now not real good until 5000 rpm then pulls really hard to 7200.
Old 12-13-2002, 06:45 PM
Post
not sure of car weight pretty heavy 75 camaro
Old 12-14-2002, 04:17 PM
Post
thanks for the replies bob and double vision a cam has been selected roller comp cams 236 dur 550 lift . thanks
