Cam Characteristics Help
this cam has been recomended for my 31 coupe, it has, 1969 466 lincoln mtr., roller adj. hyd lifters, w/ 4spd and 2.73 gears.... Intake specs:opens 32, closes 72, tdc overlap 70, lift .545, dod 284. exhaust: opens 78, closes 38, lift 545, dod 296.. what will be the characteristics of this cam...any help will be appreciated.
i told the builder i wanted a lumpy idle but enough vacuum to run my brakes..with what your saying it sounds like its not enough lope..dang! The vehicle is a med weight 1931 5 window coupe. ( about 24-2500 lbs guesstimate)adj roller rockers w/ guide plates, bored .030 over, rear axle ratio is stock 70 LIncoln at 2.73's. It has a top loader 4spd, 2" headers, 3' lake pipes with auger style baffles installed. N-50 tires for the rear and F78 14's in the front. A Weiand Stealth Manifold with no carb picked yet.
The LSA is 110. What is the cam duration at .050"?
From the cam card. What cam is this? Never mind I found it. This Erson "TQ40H" cam is fairly mild. 220 -228 @.050" It will not have a rough racey idle if that is what you want. If you want a rough idle you would want a different cam Try Erson cam #E260526 "HI-Flow III H" 316-316 .545 .545 108LSA This cam has 240° @.050" intake and exhaust duration 108LSA and the same .545" valve lift. For best results the cam should be degree'ed in and installed on a 104 intake C/L Thats 4° advanced. Do not guess, degree it in. It will have the rough idle and will need the distributor recurved. 24°-26°@idle 34 to 36° @ max advance. (short,limited 10-12deg advance curve) The idle will be plenty choppy. use a 750 holley or 750 Edelbrock carb rough idle, good power from 3200 rpm up may want to increase the rear gear ratio. http://www.pbm-erson.com Another good similar cam choice with a rough idle would be a Comp Cams "Thumpr Cam" comp cams #34-601-5 287TH-7 Mutha Thumpr" Degreeing it in is recomended. This cam already has the 4deg advance built in, when properly installed. Some of the Ford engine timing gear sets are retarded. Degreeing in the cam is always recomended with these motors. www.compcams.com This mutha thumpr cam will need the same distributor curve modification. Last edited by F-BIRD'88; 08-22-2012 at 05:44 AM. |
| 350 bored .060 over... XE268 cam, I didn't put a CAM BUTTON IN!!! | Dizturbed One | Engine | 12 | 08-08-2010 08:50 AM |
| Cam bearings 350 chev, cam wont fit in front bearing???? | JD's camaro | Engine | 5 | 02-07-2008 03:33 PM |
| Roller Cam Install - Cam Button & Timing Cover Help | leejoy | Engine | 10 | 12-01-2007 04:28 PM |
| characteristics of old f-100's | Iwanttolearn | Hotrodding Basics | 13 | 02-07-2005 08:33 PM |
| Cam: Calculate LCA (cam°) from lobe center angles (crank°)? | pgtr | Engine | 2 | 09-14-2004 07:28 PM |
