Cam for a Chevy 250 inline six - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2009, 09:45 PM
Hey, I am building up a 250 inline six. My plan is to get some low compression pistons and turbo charge it. I am going for horsepower over torque, I like the top end power. I am confused on what type of cam I should put in it though. Anyone help me out?
Old 12-20-2009, 11:12 PM
327NUT's Avatar
See www.inliners.com....thats all they build
Old 12-21-2009, 08:19 AM
Wiki Edits: 31
short dururation, 112/114* LSA and a high lift is what makes up a ' turbo cam '
Old 12-21-2009, 11:34 AM
fast68's Avatar
likes chevy trucks & boobies
basically the opposite of what they cam with from factory, and also opposite of an RV/towing cam. which were made for low-mid rpm torque and no horsepower. esepcially as the axle ratios went from deep in the late 60s to crappy tall ratios in the 70s and 80s.
no rpm at all.
Old 12-21-2009, 12:17 PM
How fast is fast enough?
what do you consider top end? Its all relative. Some people would say "top end" for a 250 is 5,000 RPM, which with a turbo means you want something close to an "RV" grind.
More details will get you a better answer.
Early Chevy BB Groved Cam fosterdl Engine 8 11-30-2008 09:11 PM
small block chevy cam change hardsixstring Engine 1 05-23-2006 06:38 AM
Cam guestion for SB chevy 350 sabino56 Engine 4 08-07-2005 03:13 PM
Big Block chevy cam help deuce_454 Engine 4 05-20-2002 12:15 PM
350 chevy: stock cam or 3 quarter cam ? 65roln Engine 8 03-19-2002 11:18 AM
