Cam choice for 11:1 400sbc
Hi
Im trying to work out if i need to change the cam in a 400sbc as i think the Dynamic Compression will be to high heres some info 4 bolt 400 sbc 30 thou over speed pro hyper flat tops standard rods and crank 041 heads 1.94 1.5 valves ported flow around 194cfm port matched victor jnr manifold 750dp current cam isky z25 201025 adv dur 278 dur @50 240 480 lift using 100 octain fuel I found a comp calc at http://www.kb-silvolite.com/calc.php?action=comp and worked out static at 10.8 and dynamic at 9.6 Do you think i can get away with the current cam or will i have problems??? Heres a dyno2000 file http://www.4shared.com/file/178699146/d03837cd/400.html |
Yeah im not to sure on the flow as i tested them using my home made flow bench so it could be more.
The heads are the small valve version, they are pocket ported fairly well and a clean up of the runners, looks like the valve guids have been cut down a bit. Theres no work done in the chambers in regards to valve shrouding. I can only compare them to a set of fully ported 186's and they flow about 10% more and alot more after 500 lift. I dont think i can do much more to the 041's other than go up in valve size. Added some pics, i could remove some from around the vavles but i dont think its worth the trouble.
The valves look to be sunken pretty good, this will account for some flow losses, especially low lift. You might consider going to 2.02" x 1.60" valves just to get them 'on top' of the chamber. You can use a head gasket to scribe a line that is safely inside the gasket's circumference to unshroud the valves a bit.
The port work is hard to make out- but doesn't really look too good, does it? You might want to spend some time just smoothing and blending what's been done, w/o actually changing the port shape any more than already done. |
| What cranking compression for use with 87/89 octane?-- relating to cam choice | 383ram | Engine | 3 | 02-20-2009 04:59 AM |
| SBC cam choice | 1939P7 | Engine | 9 | 01-01-2009 03:09 PM |
| XE274H cam sound like? Heads Choice? Help me decide on combo for chevy 400 | Warrant | Engine | 10 | 03-01-2006 02:58 PM |
| Cam choice for new GM 260hp crate motor | Iceberg | Engine | 3 | 02-21-2005 11:03 PM |
| Pontiac 400 cam choice? | steppenwolf | Engine | 9 | 11-26-2002 07:23 AM |
