cam choice - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2007, 09:58 PM
cam choice
i have a 80 chevy truck with 350 40 over performer intake gm head with 202 160 heads headers and a holley 750 or a 600 quadjet carb. would this cam be allright SUM-K1105 Summit Cam and Lifter Kits
Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 282/ 292, Lift .465/ .488, Chevy, Small Block, Kit with stock stall and which carb do you think would be better to run. also any idea of what kind of numbers i would get??? thanks for all the input.
Old 03-03-2007, 10:11 PM
techinspector1's Avatar
Wiki Edits: 326
Incompatible with stock compression ratio and will need minimum 2200 stall converter.
Old 03-03-2007, 10:27 PM
Comp Cam
Try Comp's truck cam grind# 12-231-2 go on line and reference it on Comp Cam's page. You can also get Summit to get you one by teling them the grind # It is an "Extreme 4x4 cam". Don't over cam it is bad vodo!
Old 03-03-2007, 10:42 PM
i have a edlebrock performer cam now but wanted to bump it up a little if possible.
Old 03-03-2007, 11:03 PM
Ok
Cam puts out to a point and then the the engine must change. If you bought the intake and cam as a kit you may be able to go up one more but call Edlebrock they give ok tec. If you want more you will need more flow (porting), bigger valves, and a higher compression ratio. These mods will sometimes require a new botom end. There is software out that will give you expected outputs for given components, I think comp has it and you may pay but it will warn you when you go to far. If you don't want comp's software then google engine simulation software!
Old 03-04-2007, 07:33 AM
That cam is a little stronger than what I have in my new 383 at 10.5cr and I believe I hit pay dirt with it. That is a lot of duration for a 350 , I agree.
Old 03-04-2007, 08:21 AM
i read somewhere that comp cams said that the biggest cam you can use with no stall is a xe268h Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 268/ 280, Lift .477/ .480, Chevy, Small Block, Kit. would this be better. i wish that cam line was open on sundays i a goin to call monday.
Old 03-04-2007, 05:53 PM
Luck
Good luck tell us what happens!
Ps the carb #'s are good but a rejet may be required.
Old 03-04-2007, 06:32 PM
mynuffinfutsitch's Avatar
i run a stock convertor with the cam a lil bigger than the one u have
292 .488 lift (single pattern)
i also have a 81 chevy pickup
im very plz with my cam it pulls hard all through the rpm range
im running vortec heads (the dart cast ones), a high riser, and a holly 600
oh and the gears in the rear are 3.08 and the tranny is a th350c, itll smoke the tires and then want to shift
XE274H cam sound like? Heads Choice? Help me decide on combo for chevy 400 Warrant Engine 10 03-01-2006 02:58 PM
cam choice??? ko.17 Engine 9 03-20-2005 12:12 PM
Cam choice for new GM 260hp crate motor Iceberg Engine 3 02-21-2005 11:03 PM
The cam mistake is running, well, kinda! Jmark Engine 12 12-31-2003 12:49 AM
another cam ouestion...ie...cam timing VETTE GUY Engine 0 06-28-2003 11:29 AM
