Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam choice
Thread: Cam choice
Old 01-07-2013, 05:36 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
First you say you're rebuilding a 305 and ask what cam to use. Later on, you tell us that the cylinder pressure is 159 pci (I assume you meant psi). Do you currently have a running motor, but plan to tear it down for a rebuild? You couldn't have checked cylinder pressure unless the motor was somewhat together.
