cam choice - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2011, 11:40 AM
cam choice
Ok guys. I have a 91 s10 small block 350 of course. Its a 93 model block with an 868 model 700r4. The crank is turned 10/10. Stock heads headman headers. Regular cam. I have some FI heads that were freshly done awhile back seting at my buddies.they are withered 202 valve or 194s. What cam would be a good choice? I was looking at a lunar voodoo cam and lifter kit with a 454 lift. Is that too big?
Old 10-20-2011, 12:26 PM
hey bud i got a mild built 350 with vortec heads. im not sure the size of the heads. i run a 480 lift 292 duration melling cam in mine with no problem. and pretty happy with it. great sound great performance. ive even heard people putting 510 lift. but idk really about that. all i can refer to is my experience and mine does good.
Old 10-20-2011, 01:32 PM
Cool yea these FI heads have some work done so I didn't kno if there is a way to determine the best cam or not 510 lift huh? Must sound pretty good
Old 10-20-2011, 01:33 PM
Your 480 probably sounds pretty good too
Old 10-20-2011, 01:57 PM
techinspector1's Avatar
Wiki Edits: 326
The best choice of camshaft would be one chosen to match up with the static compression ratio of the motor. If you don't know the SCR of the motor, then you have no business choosing a camshaft for it.
While matching to the SCR may not be the only characteristic to help you make a choice, I can guarantee that if you don't match it up, you won't get the performance you are wishing for. Other input would be cylinder head flow figures, valve sizes, intake manifold design, CFM, transmission ratios, rear gear ratio, tire size, torque converter stall, etc., etc.
http://www.crankshaftcoalition.com/w..._compatibility
yeah it sounds good. good tough lopey idle to it. yeah i know you would need bigger springs. idk about your push rods or rockers you may or may not have to mess with them. it the vacuum sucks for the brakes tho. you got to stand on em sometimes when your in stop and go traffic. but you get use to it. its my daily driver. is this gonna be your daily driver or just your weekend truck?
Old 10-20-2011, 04:40 PM
For now it is my daily driver. Will be my weekend truck beginning of next year
Old 10-20-2011, 05:53 PM
thats cool. id like to get a s10 and make a drag truck out of it that would be pretty sweet. but idk all about the scientific stuff dude was talking about with the cam. but definatly do some research and youknow find one thats good for what you want
cam choice for my 92 f-150 motorhead454 Engine 0 08-10-2009 07:31 PM
If you had only one choice to do for HP? 1Bad406sbc Hotrodders' Lounge 12 08-10-2009 08:36 AM
Cam choice redrod4 Engine 0 01-10-2008 07:31 PM
Cam Choice gazrnr Engine 12 03-26-2005 10:54 PM
cam choice??? ko.17 Engine 9 03-20-2005 12:12 PM
