Cam Choice - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-18-2012, 01:59 PM
vinniekq2's Avatar
proven combination to attain what goal?do you want a 14 second street car? 77 Camaros are a little heavy.are you going to ever use slicks with that 4 spd? any 360 ish HP engine will get you into the 13s if you can hook the car and not break.
  #17 (permalink)
Old 08-18-2012, 02:53 PM
Gona run M/T streets when I go to the track. I plan on lightning the car little bit.
Mostly I want to be able to drive it. Had drag cars, I think I want this one to be an all purpose car. Altough I have getting the itch to get back into drags.
I may build Z to resemble a vintage Trans Am car.
I am just getting it running asap. I am going to build a more purpose built combo later on.
  #18 (permalink)
Old 08-19-2012, 05:00 PM
E.T. divided by $ spent= Speed
Don't worry about the pistons being dished. With 64cc Vortec heads you will have plenty of compression,I'm guessing in the 9.25-9.5:1 area.
Evan with 76cc heads you will have a true 8.4:1 ratio with thin head gaskets as per the many goodwrench build up articles.Which is a little low for the L79 cam but not a total mismatch,with your 3.73 + 4spd setup to make up the bottom end.
My uncle has a dished piston stock short block with the L79 cam and 462 fuelie heads(2.02s though)and that motor is plenty stout and snappy for a cruiser.......and sounds nice too.
Cam Choice grundy Engine 1 11-22-2011 04:27 PM
Cam choice,, Please help!! Lthompson Engine 23 02-09-2005 06:05 PM
Cam choice - What do you think? Rhansen Engine 9 02-14-2004 09:19 AM
Cam Choice with CR of only 8.4:1 meschnebly Engine 14 07-07-2003 01:46 AM
cam choice help Crazy d Engine 9 05-17-2003 05:21 PM
