Cam choice - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-08-2013, 11:49 AM
vinniekq2's Avatar
(And how much hp can i get with this settup )
that was the question
(240 ish from what you listed?) is the horse power I would expect
  #17 (permalink)
Old 01-08-2013, 11:54 AM
the youngone
Last journal entry: progressthe
oo isee haha thats a nice score for a 305 how much is it stock ?
  #18 (permalink)
Old 01-08-2013, 11:58 AM
vinniekq2's Avatar
most 305s are under 200 HP stock.
  #19 (permalink)
Old 01-08-2013, 12:01 PM
the youngone
ok 150 the most of them right? bud now was i m reading somthing about supercharge or turboscharge ... will it work?
  #20 (permalink)
Old 01-08-2013, 12:11 PM
vinniekq2's Avatar
super chargers work well,turbos also work well
rather than ask miscellaneous questions and getting random answers:
tell us the application for the engine and what you would like for performance.
biggest obstacle is always budget.
  #21 (permalink)
Old 01-08-2013, 12:50 PM
the youngone
wath i told here is wath my plans are
  #22 (permalink)
Old 01-08-2013, 01:52 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
In my opinion, your plans are flawed. You're thinking that you will gain some power by camming up the motor and using those low-rpm heads. Ain't gonna happen. You'll end up ruining a perfectly tractable motor. If you want more juice, pop for a 350 to begin with. I realize you're in Holland, but there must be some 350 cores there.....somewhere.
The swirl port heads were meant to make good power down low in the rpm range with a stock cam and I just don't see spending your money effectively with them as a base to begin with trying to make more power.
If you're gonna be hard-headed and stick with the 305, then at least purchase some decent heads for it....
http://www.trickflow.com/partdetail....2&autoview=sku
  #23 (permalink)
Old 01-08-2013, 02:00 PM
the youngone
no no im not expecting the world is going to bounce haha my underblock is in a good condition so i want to keep it what i want is to get out what there is in it .. the cam what i would like to use is like a edelbrock performer they told me its for more tq i know the heads ar swirls bud a little intake and out ports flowing cant be to bad for the engine .. btw 240 hp is nice for in my van ..haha
  #24 (permalink)
Old 01-08-2013, 02:58 PM
the youngone
but you are not agree of the opinion from vinniekq2 I can get 240 hp
  #25 (permalink)
Old 01-08-2013, 03:19 PM
Senior Curmudgeon
Wiki Edits: 326
Any camshaft that you bolt into the motor will have an operating range of ~3,500 rpm's. It will allow the motor to make power from idle to 4,000 or from 2,000 to 5,500 or from 3,500 to 7,000 or whatever rpm range you wish to use. AGAIN, the heads you have are optimized for low-rpm operation and will not be compatible with a camshaft that wants to operate at a higher rpm range. I continually harp on "combination", "combination", "combination because you must use parts that complement each other. If you use a longer cam with those fosdick heads, you will kill off bottom end power by virtue of more cam timing. Any power that you may make on the top end as a result of more cam timing will be killed by the heads. There's no free lunch.
  #26 (permalink)
Old 01-08-2013, 03:30 PM
the youngone
so what cam wil you recomend to my stock setup ( only flowing the ports) rest is stock dont say not anny cam wil work there are people withe same engine as me and done it before with another cam im not looking for a high performance drag engie but just a little better than a stock 305
  #27 (permalink)
Old 01-08-2013, 03:53 PM
Senior Curmudgeon
Wiki Edits: 326
so what cam wil you recomend to my stock setup?
Generally speaking, most builds such as what you're contemplating will benefit from using THE VERY FIRST OFFERING ON THE LIST from the cam grinder, particularly with heads that are designed for low-rpm operation. COMBINATION, COMBINATION, COMBINATION.
http://www.cranecams.com/56-67.pdf
  #28 (permalink)
Old 01-08-2013, 04:01 PM
the youngone
cant open the website but seE THIS Performance Camshafts, Lifter Kits and Matching Valvetrain for Small-Block Chevy - Edelbrock.com this cam is also for low rpm right?
  #29 (permalink)
Old 01-08-2013, 04:32 PM
Senior Curmudgeon
Wiki Edits: 326
Here's the Crane cam....
Crane PowerMax Cam and Lifter Kits 114102 - SummitRacing.com
Here's the Edelbrock I might use....
Edelbrock Performer-Plus Cam and Lifter Kits 3702 - SummitRacing.com
I like the Crane cam because of the 104 degree lobe separation angle, contributing to low end torque. The Edelbrock cam uses 112 and I don't care for that. It favors higher rpm's, something you will not see with your heads.
I might also use this cam....again,....104 degree lobe separation angle and a little more lift than the 114102 cam.
http://www.summitracing.com/parts/crn-114112
Here's Crane's description of the 114112 cam.....
Great for 305 and 350 engines in cars, light and intermediate trucks with optional gearing (or shorter tires). Good low and midrange torque and HP.
Grind number 2020
Oprating range 800-4400 rpm's
Part number 114112
Use lifters 99277-16.... Use springs 99848-16
Duration @0.050" tappet lift 194/204 254 104 (7) 21 .000 .401
Duration @advertised 254 / 264
Lobe separation angle 104 degrees
Intake open/close (7) / 21
Exhaust open/close 26 / (2)
Valve lift 0.401" / 0.423"
Read through this tutorial several times to make sure you understand the precautions of using a flat tappet cam.....
http://www.crankshaftcoalition.com/w...ips_and_tricks
  #30 (permalink)
Old 01-08-2013, 04:41 PM
the youngone
oke thanks so the crane cam and edelbrock plus are a little like the same onley the edelbrock has a higher rpm but now the question hom much hp wil i get with my plans an a cam like one of these ,
thankyou for the explainations .. here in holland the know not much about it haha
Cam choice? schatzy Engine 3 09-28-2010 07:00 AM
help with a cam choice powerrodsmike Engine 24 07-30-2006 10:42 PM
Cam Choice gazrnr Engine 12 03-26-2005 10:54 PM
Cam choice,, Please help!! Lthompson Engine 23 02-09-2005 06:05 PM
Cam choice Schoust Engine 0 02-04-2004 11:30 AM
