Cam choice - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 01-08-2013, 05:56 PM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by Wezz View Post
oke thanks so the crane cam and edelbrock plus are a little like the same onley the edelbrock has a higher rpm but now the question hom much hp wil i get with my plans an a cam like one of these ,
thankyou for the explainations .. here in holland the know not much about it haha
Back up and read post 29 again. I added some stuff after you posted. Pay particular attention to the Crane 114112.
Your question about hp cannot be answered intelligently. There are too many variables. You might just as well ask "how long is a piece of string?"
Once you get everything together, take the van to a facility that has a rear wheel dynomometer. Multiply the rear wheel hp that you get by 1.25 to get close to flywheel hp.
One last thing, please stop harping on hp. Torque is what you want, not hp.
  #32 (permalink)
Old 01-08-2013, 06:03 PM
the youngone
Last journal entry: progressthe
Ok. I have still 2 questions . On the summit website they recomend. Also valve springs. By the crane cam .. Bij the edelbrock they did not its a bit wierd .. Dnt you think so . And question 2 has porting the exhaust valve any sense
  #33 (permalink)
Old 01-08-2013, 06:12 PM
Wiki Edits: 326
1. There are many wierd things on this planet, including some of the people on this site. Bottom line, ALWAYS use the valve springs recommended by the cam grinder for that particular grind.
2. Porting the exhaust valve? Well, you don't port the exhaust valve. You port the exhaust port. That's why it's called porting and not valving.
You'll notice that the 114112 cam has different duration and different lift from the intake valve to the exhaust valve. This additional lift and duration on the exhaust side seems to help some on heads that don't flow as well on the exhaust side as they do on the intake side (true of most production heads).
You have the option of grinding on the heads any way you want to, they're YOUR heads.
  #34 (permalink)
Old 01-08-2013, 06:21 PM
vinniekq2's Avatar
weird person chiming in,,lol.
Torque is what you feel in the seat of your pants. This is why stroker engines are so popular now.I built a stroker for the torque and was very happy with the results.Back in my youth we build 283s for high RPM. We had 3 speed transmissions and the race was won or lost in first gear. Now adays if you have a 4 speed people think you are behind the times. Using 5 speed transmissions and torquey engines and you feel like you are driving a race car and still get daily use with the over drive. Low RPM engines last a long time
  #35 (permalink)
Old 01-08-2013, 07:23 PM
1971BB427's Avatar
Wezz,
Take a look at this Popular Hotrodding 305 engine build before you start buying parts. If you're dead set on keeping it a 305, then as mentioned the right cam and heads will be needed to get more out of it.
At the very least you should consider having a machinist upsize the valves and springs if you go much over stock with a cam.
http://www.popularhotrodding.com/eng...s/viewall.html
  #36 (permalink)
Old 01-09-2013, 12:33 AM
the youngone
Ok thanks . And no i dont expect 370 hp haha. Thats a realy nice engine . I keep it with that cranecam or edelbrock .. Not sure wich one its gonna be. And keep the 187 heads. I wil take the exhaustports nice with the gasket. And.thats it but thank you all
  #37 (permalink)
Old 01-09-2013, 01:02 AM
the youngone
Stil have a question . Stock my block had a roller cam but the edelbrock and cranecam have both flatt tapped ..so what d i need to do going to flat tap or hold the roller valve lifters in
  #38 (permalink)
Old 01-09-2013, 03:13 AM
Wiki Edits: 326
Crane Hydraulic Roller Camshafts 104201 - SummitRacing.com
http://www.cranecams.com/88-89.pdf
Springs....
http://www.summitracing.com/parts/crn-99848-16
  #39 (permalink)
Old 01-09-2013, 03:18 AM
the youngone
Ok. Thats a whole different. Price haha
Cam choice? schatzy Engine 3 09-28-2010 08:00 AM
help with a cam choice powerrodsmike Engine 24 07-30-2006 11:42 PM
Cam Choice gazrnr Engine 12 03-26-2005 11:54 PM
Cam choice,, Please help!! Lthompson Engine 23 02-09-2005 07:05 PM
Cam choice Schoust Engine 0 02-04-2004 12:30 PM
