-   -   Cam choice (http://www.hotrodders.com/forum/cam-choice-228097.html)
Wezz 01-07-2013 04:23 PM
Cam choice
Hello i am wesley . And i am from holland. I am rebuilding a 305 yes i know its not spectacular but its my first v8
I wil geve the engine a edelbrock performer manifold with a edelbrock 600 carb also i want a better camshaft. . So now the question what cam can i run on a stock engine . I was thingking of the edelbrock performer plus 2102 but can i run it with my stock valvesprings ?
Thanks
GMC boogie 01-07-2013 04:54 PM
I think that is a nice choice. Summit SUM-1102 may save you a few $.
Allthough not entirely nessessary, I would change the valve springs. It is a small investment,around $30-40 for a decent set to compliment that cam.
New valve stem seals while your in there also.
Wezz 01-07-2013 05:00 PM
Cam choice
Summit is that a cheaper cam? Btw yes. Al of the gaskets and seals ar getting new . I m thinkin to port the heads also .. Good idea wil it give a good job after porting? How much hp can i run if i m luckey?
Thnx
Wezz 01-07-2013 05:10 PM
Cam
Hello the block is a 14093627 and the heads are 14102187
In 1.88 out 1.5 i did a compression test and i came out with 159pci on each cil
What springs would you recomend ?
Thnx
GMC boogie 01-07-2013 05:34 PM
These will do fine:
Howards Cams Performance Street/Strip Valve Springs 98111 - SummitRacing.com
techinspector1 01-07-2013 05:36 PM
First you say you're rebuilding a 305 and ask what cam to use. Later on, you tell us that the cylinder pressure is 159 pci (I assume you meant psi). Do you currently have a running motor, but plan to tear it down for a rebuild? You couldn't have checked cylinder pressure unless the motor was somewhat together.
Wezz 01-07-2013 10:17 PM
Yes i mean psi . The engine was running good before bud i want to rebuild it and perform it a little .. But anyone a idea for the springs
Thnx.
vinniekq2 01-07-2013 11:26 PM
the summit cam sounds about what you need. Maybe tech can help you dial it in.
Wezz 01-08-2013 02:31 AM
Btw do i need hydroulic roller lifters or are flatt tapped good enoug?
Wezz 01-08-2013 10:43 AM
Anyone? And how much hp can i get with this settup
Thanks
vinniekq2 01-08-2013 10:54 AM
give a complete list of the parts you intend to use if you want something better than just a guess.With diligent work and a decent supply of "quality" parts, one horse power per cubic inch is easy to attain.
Wezz 01-08-2013 11:19 AM
ok engine a stock 305 (code 14093627) heads 14102187 58 cc
cam summit sum 1102 manifold edelbrock performer carb a edelbrock 600cfm and headers
the heads are getting a little flowed
vinniekq2 01-08-2013 11:43 AM
240 ish from what you listed?
Wezz 01-08-2013 11:46 AM
sorry i dont understand u
vinniekq2 01-08-2013 11:49 AM
(And how much hp can i get with this settup )
that was the question
(240 ish from what you listed?) is the horse power I would expect
